Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I've inherited an older part numbering scheme, in which ceramic capacitors are divided into disc and monolithic types. Is this actually a firm division in their characteristics? If so, what are the differences? Is that nomenclature common, or are other names used more often? Are there other classifications of ceramic capacitors in addition to those two?
Edit: If I have two capacitors, a monolithic and a disc, of equal voltage and capacitance, why would I use one over the other?
share|improve this question
up vote 7 down vote accepted
If by monolithic, you mean the multi-layer chip caps (sometimes labled MLCC), that's what all the high density ceramic caps are.
The traditional disc caps are basically just a slab of ceramic with plate on each side, radial leads attached, and dipped in epoxy or maybe ceramic for coating. These are low capacitance devices (100 or so pF) but can be very high voltage. Sometimes they are also called safety caps.
Also, there are disc or cylindrical shaped caps that are really MLCC structures with an electrode around the outside edge and the other electrode in the middle. These are used as feed through caps in housings of EMI filters, or maybe even as part of a transmission line termination.
Wikipedia has a pretty good write-up of capacitors here.
Edit:
The question of the disk cap and MLCC having the same voltage rating and capacitance and having to choose between the two occupies a very small space in the Venn diagram. MLCCs were derived from disc technology to overcome limitations in capacitance and allow wider use of ceramic dielectrics which are comparatively easy to fab. The main things the disk has going for it are the high voltages and rugged construction. A single wafer of ceramic is going to take more abuse than a stack of thin layers of ceramic. The choice would come down to things like that.
If you needed a rugged part, or a part that could not be surface mounted you would choose the disc (I know you can get leaded multilayer ceramics, but its a disappearing market). If you needed a part with low ESL and more compact size you would choose the MLCC. It's pretty clear which is usually more desirable.
The uses for disc type caps really are those for which it has an advantage, like high voltages from 3kV to 6kV where you might need a low dissipation coefficient or NPO type stability. MLCCs don't offer much competition at those higher voltages.
share|improve this answer
I got the following answer from an engineer at CDE:
I would think that ceramic disc capacitors would tend to be cheaper and in the past there was a wide range of positive and negative temperature characteristics that were useful in circuit design. Ceramic discs also had higher voltage ratings. Nowadays MLCC parts tend to be more readily available, digital circuits only need low voltage parts and the T.C. characteristic isn’t as important except for cost. Ceramic disc caps tend to have very high minimum orders.
And this from Vishay:
The construction of disc capacitors is much less complex and thus they are much more rigid both mechanically and electrically, especially concerning the pulse strength.
So pretty much what gsills said.
protected by W5VO Jun 20 '13 at 4:48
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
