Tell me more ×
Assume that I do not want to replace a factory Engine Control Unit (ECU) with a custom ECU.
What are the other possible intercept points that I can use to allow/prevent a car from starting up? I only want to allow/prevent starting up.
I can think of possibly connecting the car battery through a relay and turning the relay on/off. Any other good ways to do it?
share|improve this question
There is a product made that is designed to be a simple switch between the battery and the car. You have to pop the hood to get to it, but I would bet most people who steal cars don't want to go to this trouble. I have always seen it used for people who have 2 home and leave a car unused for months at one or the other and don't want the battery to be drained by all of the little things that the car always has on. – Kellenjb Dec 3 '10 at 14:48
up vote 11 down vote accepted
There are many ways to achieve this. Some are better than others in certain situations, and some only work on certain cars. I'll try to describe a few.
  1. This is the most commonly used way. Put a switch (relay, etc.) in line with the starter control signal. This would generally be put before the starter relay itself. It prevents the starter from turning over the engine.
    • Pro: Works on nearly all cars.
    • Con: The car can still be started if you find a way to turn over the engine (pushing the car in gear if it has a manual transmission).
  2. Intercepting a major sensor. These sensors generally deal with crank angle/position. A lot of times a car would only have one, angle or position. They may also be called a cam angle/position. Activated with a switch (relay) intercepting the signal wire coming back from the sensor.
    • Pro: The car will not start no matter what you do since the ECU will think the engine is not turning over and will not provide spark.
    • Con: Only works on cars that use these sensors. Older cars relied on mechanical versions of these.
  3. Intercepting main power like you mentioned. This would require a hefty relay or switch. It is not uncommon for cars to have fuses larger than 100A for the main input.
    • Pro: Would work on most cars.
    • Con: Difficult to do. Easier to find than others (I'm assuming this is to prevent the car from being stolen). Does not work on really old cars that used generators instead of alternators. May mess with modern electronics in the car itself possibly leading to damage.
There are other ways but pretty much all of them would fall under these categories if you want to be able to control it electronically. Don't forget that the car can always just be towed. Once again, I'm assuming you are thinking of theft prevention.
share|improve this answer
I like the intercepting a major sensor, that's a great idea, not many thieves will sit and troubleshoot a car's system to figure out why it's not starting, if they can't bypass the ignition or pop a cable back on the battery, they're not going to stick around much longer. – onaclov2000 Dec 2 '10 at 13:29
Thanks for the edit Nick. I need to learn how to do that myself at some point. – Andrey Dec 2 '10 at 16:03
Pretty good answer, needed to look pretty. :P – Nick T Dec 2 '10 at 17:59
You could lock up the breaks, really effective, especially if the car is capable of locking up all 4 wheels. Makes it very difficult to tow. – Kellenjb Dec 3 '10 at 14:49
Rather than intercept the battery cable feed, you could intercept the signal from the key to the ignition relays/contacters. That way you won't loose your radio station programming due to battery being disconnected.
When I say intercept I mean break the connection, insert a relay or transistor and drive it with some circuit that allows\disallows engine start, run.
Whatever you're doing, try to make it so the engine won't stop in the middle of driving. This safety message has been brought to you by.....
It depends on tech level of the car and how difficult for you want the system to be and WHY YOU WANT TO PREVENT THE CAR FROM STARTING. The why part is very important because if you just want the car to not start, the ignition key/switch is the most obvious way and has been in use for a really long time. If you want to prevent someone form stealing your car, you'd need to know what would the thief be capable of and how difficult you want the system to be for day to day use. I mean, you could always take the battery with you, but that would add a few minutes of setup time every time you want to start the car, plus problems related with carrying the battery.
Some cars have electrical central locks which will not work if the battery is disconnected. It could also cause problems with internal clocks, microcontroller settings, radio settings and so on.
If you want to stop the car from starting, maybe it wouldn't be a bad idea to put some sort of switch at the starter itself. This way, the rest of the car's electronics could still work. To me this looks like the safest place because, as far as I can see, attempting to start a car with disconnected starter will cause the least amount of damage. Please note that the last car I worked on was a Volkswagen Golf Mk1 and that was quite a while ago, so I'm probably out of date.
Another idea would be to analyze how car's starting procedure goes. Some cars have a key controlled rotary switch which is used to start the starter. If you add another switch in series with the starter switch, you could prevent car from starting.
Some other cars I've seen have a start button which is directly connected to a microcontroller, and they would be a bit more difficult to intercept.
I'd like to prevent unauthorised access to the car. – sybreon Dec 2 '10 at 13:50
@sybreon: A brick will still allow someone "access" to your car. Or do you mean start and drive it? – Nick T Dec 2 '10 at 15:55
hehe.. yes, start and drive it. :) – sybreon Dec 3 '10 at 1:20
I second Jim's idea: switch off fuel pump/injector(s). If the motive is theft prevention this has a major advantage: when you try to start the engine the starter motor will still run, but the main engine doesn't. The thief may think there's something wrong with the engine and leave the car alone (car thieves don't really want to interrupt their criminal business to repair a car engine).
OTOH, if nothing happens, like when the main contact is switched off, they may have a clue of what the protection is about, and quickly "fix" it.
Another possibility is a cut off switch for the fuel pump. No fuel, engine will turn over but not start. This can be a hidden toggle switch or a separate key switch.
There may be fuel in the line near the engine and so the engine might run for a bit and then suck air. Not good for the engine. – Matt Williamson Dec 2 '10 at 15:21
@Matt: I'd imagine a fuel pump failing (or running out of fuel) should not cause actual engine damage. Automotive engineers aren't that brilliant, but they like their DFMEAs. – Nick T Dec 2 '10 at 15:54
That's a good idea Jim C. I knew I'd forget some things. Sucking in air with fuel pump off shouldn't damage the engine at all, in fact modern engines shut off injectors (effectively same as shutting off fuel pump) when at high RPM with no load to save gas. The only real negative would be the fact that the engine will require a little bit more cranking on the first start after someone tries to start it with the pump off as the pump will have to pressurize the fuel lines first. – Andrey Dec 2 '10 at 16:06
I once heard of a system based of this idea for Yugo (which is famous for it's unreliability). Unless it's turned off, after about 5 minutes it would intermittently start cutting power to the fuel pump and after couple of minutes more cut power completely. In the end, it looks like the car broke down (which isn't uncommon for that type of car). On the bad side, it's unsafe and you have to search the ~10 minute radius if someone does steal your car. – AndrejaKo Dec 2 '10 at 17:40
A method I've seen a few times is shorting the spark line coming into the distributor, as others have already mentioned.
My grandfather made up a special wire for the distributor center lead. It looked just like a real wire with the right plugs on the ends, but had no conductor in the middle. When he had to leave the car for long periods of time someplace he didn't trust, he'd swap in his fake wire and hide the real one. The engine will turn but not start. A quick or even not so quick look under the hood won't reveal the problem. It would take far more diagnostic effort than a thief wants to spend to get the car working.
The method doesn't need to be unbeatable, only enough trouble to make someone else's car a easier mark.
I'd just add a toggle switch that's normally open, cutting either the park/neutral (automatic) or clutch (manual) switch. You're dealing with very minimal current, and the car is designed to not start without said signal; you're not placing it in some uncommon failure mode.
Granted, if someone troubleshoots this it would be one of the first things to check, but determining where the problem is and how to fix it can take a long time depending on how you wire it up.
Probably late to answer this question; I'll do so anyhow.
In my old car ( no fuel injection, had a distributor+carburettor ), what I did was to pull a wire from the distributor earth into a switch with the other connection going to the chassis. Keeping the switch open prevented the ignition circuit from closing, and the vehicle wouldn't start.
Uh. Just what AndrejaKo said...
  1. Disconnect the battery..
  2. Disconnect the Coil Wire. No spark, no engine start/run
  3. older Cars pull the distributor rotor. Same as #2
  4. Disconnect the Ballast Resistor.. car will start but not run.
  5. Pull the starter relay or its fuse/circuit breaker.
discard
