I am trying to create a small motor driver for a DC motor, 9v-12v, max current and stall current i do not know, but I am using the stock motor of a Blade CP Helicopter. I just want to know if i am using parts that will work, and what parts i should replace. The FET i am using is a 22N50 N channel FET. Any advice or things i should look out for?
Motor will be only going one direction and will be controlled from a 3v-5v PWM
yes i know about the diode across the motor which is a 1N4000 link to diagram
link|improve this question
Do you have the motor part number? – tyblu Dec 7 '10 at 8:33
its a 370 Motor, i looked for more info but not too much on it – jsolarski Dec 7 '10 at 8:50
well the design works, but i dont know the limitations or what could fail. youtube.com/watch?v=fGv7ZcKn0Z0 tested with 5v through the motor, 5 volts on gate – jsolarski Dec 8 '10 at 9:54
feedback
1 Answer
up vote 1 down vote accepted
A quick search on the 'net' gives the following
Model: R370
Round type diameter: 24.4 x 30.8 (L)
Voltage (V): 6.0 No load current 0.03 A; speed 4,950 rpm Max efficiency current 0.19 A; speed 4,280 rpm; torque 19 gcm Max output current 0.625 A; speed 2,475 rpm; torque 170 gcm Stall current 1.22 A; torque 140 gcm
Voltage (V): 31.0 No load current 0.035 A; speed 11,140 rpm Max efficiency current 0.2 A; speed 9,530 rpm; torque 43 gcm Max output current 0.63 A; speed 5,570 rpm; torque 149 gcm Stall current 1.22 A; torque 298 gcm
  • This sounds like a possible for your motor...
If the motor you have is about this size (24.4mm Dia x 30.8mm L), then its stall current will be about the same.
And for your FET - a max current around 22A peak around 80A
This FET should easy handle the stall current for your motor.
link|improve this answer
I think that answers my question about the schematic, thanks! I am going to have to email the manufacture for the exacts, about the motor, but it looks pretty close to the r370. – jsolarski Dec 13 '10 at 2:28
370 is a standard size of 'toy' motor - it appeared in radio controlled cars in about the late 1970's - there were a couple of motors that were used - the big one was the 540 can size. - the main difference between the motors was how the coils inside were wound. For racing cars a thicker wire would be used that would take a lot more current, but the downside was the batteries would run down quicker... (And everything would have to take a lot higher current) – Wonko The Sane Dec 13 '10 at 22:28
As you motor is from a model helicopter, the motor is a more standard design - and won't have specs much off the ones quoted for the R370 - I would say a max stall current of no more than 5 Amps... – Wonko The Sane Dec 13 '10 at 22:31
You could test the stall current by just connecting the motor across a supply with a meter and stall it - but only for less than 2 seconds... – Wonko The Sane Dec 13 '10 at 22:32
Your design for a motor controller is simple, it seems to work and should be capable of handling the stall current from your motor. :-) – Wonko The Sane Dec 13 '10 at 22:33
feedback
or
required, but never shown
