Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have a 20.000 Mhz Crystal Oscillator Module. If I just wanted to transmit a carrier wave at 20 megahertz, what would be from A to B?enter image description here
share|improve this question
It depends on how strong a signal you want to transmit; you may need an amplifier of some sort. Also, you'll almost certainly want a filter of some sort to limit the bandwidth of the transmitted signal. For example, if it's a square-wave oscillator, you'll want to eliminate the harmonics at 60, 100, 140, etc. MHz. This could be accomplished with a simple L-C tank circuit. – Dave Tweed Jul 23 '13 at 20:46
I checked with my scope, and the wave looked sine – skyler Jul 23 '13 at 20:49
@skyler are you sure your new scope has the bandwidth to show a decent squarewave at 20MHz without it looking a bit rounded and sinusoidal. A simple output filter would help clean things up and because it's unlikely you'll be using a full 3m 1/4 wave antenna (because you might get into trouble with the authorities) there are passive filters that might get you +6dB output on the bare oscillator o/p – Andy aka Jul 23 '13 at 21:08
It's rather difficult to answer this question without more specific information. Maybe you need nothing. Maybe you want an impedance matching network. Maybe you want an amplifier. What are the components? What are the requirements? – Phil Frost Jul 23 '13 at 22:34
@andy aka : My scope is the owon pds5022. I am very new to it so maybe my settings are off – skyler Jul 23 '13 at 23:10
up vote 0 down vote accepted
My guess would be an ATU (aerial tuning unit) consisting of inductances and variable capacitors.
share|improve this answer
Keep the output clean with a filter that can apply a little gain at 20MHz. Here's an unusual one that gives higher Q the more you load it: -
This has been simulated from an earlier filter design I did but you'll still need to tweak values such as C1 and C3 - I suggest 10pF trimmers.
discard
