Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Is there anyway I can connect resistors to allow them to take more power such as using 4 1/4 watt resistors to get a 1 watt resistors. Or do i just have to use 1 1 Watt resistor.
share|improve this question
up vote 28 down vote accepted
Yes, you can use (4) 0.25 W resistors to dissipate 1 W and still remain within each individual resistor's power rating. This can be accomplished a few different ways:
  • Place them all in series:
    • In which case you will need to use resistors with 1/4 the resistance that you want overall.
    • e.g. If you want 1 kΩ total, put (4) 250 Ω (240 Ω nearest 5% standard) resistors in series.
  • Place them all in parallel:
    • In which case you will need to use ones with 4 times the overall desired resistance
    • e.g. If you want 1 kΩ total, put (4) 4 kΩ (3.9 kΩ nearest std.) resistors in series.
  • Placing them in a 2x2 array:
    • Where you can use resistors of the same resistance you want overall (2 in parallel gives half, but you place 2 sets of parallel in series, doubling the effective resistance)
In all the mentioned cases, in order to have each resistor dissipate an equal share of power, they all must be equal in value (ohms). This isn't the only way to do it, there are several other combinations you could use with differing values, etc.
Pragmatically, if you're only operating this circuit very intermittently (few seconds at a time), you might be able to get away with a single 1/4 W resistor, especially if this is on a breadboard (be careful not to melt stuff). Higher power resistors often are specified to survive surges of 8-10x their normal power dissipation for several seconds, though the typical 1/4 W thru-hole resistors are carbon film, which is a little less tolerant of this.
share|improve this answer
Beaten to the punch! ;) – tyblu Dec 17 '10 at 17:06
+1 especially for the 2x2 array, which I wasn't aware of. – mskfisher Dec 17 '10 at 17:48
@mskfisher, for every chain in parallel you should add one in series. 3X3 or 4X4, the divide factor is 1/N so you need N in a row to cancel it out. – Kortuk Dec 17 '10 at 18:41
+1 for complete details. – omeid Dec 17 '10 at 19:11
Yep, putting them in parallel increases the group power dissipation and lowers group resistance. You still need to calculate power dissipation separately.
$$R1 \parallel R2 = \frac{R_{1}R_{2}}{R_{1}+R_{2}}$$
$$P = IV = I^{2}R = \frac{V^{2}}{R}$$
If you have N resistors in parallel and they are all the same value, power dissipation will be N-times their individual rating and group resistance will be 1/N times their individual rating.
discard
