My objective is to show the results of:
- How do I go about intentionally aliasing a signal?
- undersampling
- Nyquist rate sampling and oversampling
I'm first going to get the MATLAB code working well, then I'll rewrite it for the MSP430.
First I need to downsample the .wav file to get an incomplete or impartial data stream that I can then reconstuct. Here the flow chart:
analog -> sampling analog filter -> ADC -> resample down -> resample up -> DAC -> reconstruction analog filter
This is my first signal processing project using MATLAB (v2010), so be nice. Original code below; updated code here.
%Play decimated file ( soundsc(y,fs) )
%Play Original file ( soundsc(play,fs ) )
%Play reconstucted File ( soundsc(final,fs) )
[piano,fs]=wavread('piano.wav'); % loads piano
play=piano(:,1); % Renames the file as "play"
t = linspace(0,time,length(play)); % Time vector
x = play;
y = decimate(x,25);
stem(x(1:30)), axis([0 30 -2 2]) % Original signal
title('Original Signal')
figure
stem(y(1:30)) % Decimated signal
title('Decimated Signal')
%changes the sampling rate
fs1 = fs/2;
fs2 = fs/3;
fs3 = fs/4;
fs4 = fs*2;
fs5 = fs*3;
fs6 = fs*4;
wavwrite(y,fs/25,'PianoDecimation');
%Downsampled version of piano is now upsampled to the original
[PianoDecimation,fs]=wavread('PianoDecimation.wav'); % loads piano
play2=PianoDecimation(:,1); % Renames the file as "play
%upsampling
UpSampleRatio = 2; % 2*fs = nyquist rate sampling
play2Up=zeros(length(PianoDecimation)*UpSampleRatio, 1);
play2Up(1:UpSampleRatio:end) = play2; % fill in every N'th sample
%low pass filter
ResampFilt = firpm(44, [0 0.39625 0.60938 1], [1 1 0 0]);
fsUp = (fs*UpSampleRatio)*1;
wavwrite(play2Up,fsUp,'PianoUpsampled');
%Plot2
%data vs time plot
time=(1/44100)*length(play2);
t=linspace(0,time,length(play2));
stem(t,play2)
title('Upsampled graph of piano')
xlabel('time(sec)');
ylabel('relative signal strength')
[PianoUpsampled,fs]=wavread('PianoUpsampled.wav'); % loads piano
final=PianoUpsampled(:,1); % Renames the file as "play"
%resampleing
x=piano(:,1); % Renames the file as "play"
m = resample(x,3,2);
**%this is were i would need to sample it at the different frequecys (both above and below and at) nyquist frequency.*I think.***
soundsc(left,fs) % shows the resaultant audio file , which is the same as original ( only at or above nyquist frequency however)
How can I improve this? How do I sample at different frequencies?
Note that I've crossposted this on SO, here.
