There are many benefits to inline functions over preprocessor macros:
- Type checking. The compiler will complain if the arguments are of incorrect type.
No risk of multiple evaluation: macros can be dangerous when the argument is an expression, consider:
#include <stdio.h>
#define square(n) ((n)*(n))
int main(void)
int x, i = 0;
while (i < 10) {
x = square(i++);
printf("%d\r\n", x);
return 0;
- Can include multiple lines of code without trailing backlashes.
- Inline functions have their own scope for variables and they can return a value.
Macros can be useful e.g. when concatenating tokens into code, so as to simplify some complex declarations.
Consider macros as just a dumb text replacement functionality. A good rule of thumb is to avoid function-like macros, unless there is no other viable solution.
It is a common misconception that inlining always equals faster code. Keep in mind, that every inlined call from more than one place adds up to code size. Premature optimization is not a virtue, even when working with the constrained resources of a microcontroller.
GCC interprets the inline keyword as a mere hint. There is no guarantee thet the function will actually be inlined. To have GCC inline your function regardless of optimization level, declare the function with the always_inline attribute:
void function() __attribute__((always_inline));
