In the documentation for a radio chip, I keep seeing the term 2-FSK, which seems to be a modulation scheme.
My understanding is that in FSK, data is encoded by emitting a carrier wave on a number of different frequencies. Is this right? How does this differ to 2-FSK?
link|improve this question
What is the chip? – Leon Heller Jan 11 '11 at 17:51
@Leon Heller - the Chipcon CC1110 – Joby Taffey Jan 11 '11 at 18:41
feedback
up vote 7 down vote accepted
The number '2' refers to the number of tones used to encode the signal. For example, 2-FSK is essentially sending binary data using two frequencies. One symbol (time slice) has the potential for two values only. 2-FSK is usually what is meant by an unqualified mention of FSK.
It's possible to use more than two tones. These modulation schemes usually are called MFSK for Multiple Frequency Shift Keying. A common MFSK scheme in amateur radio is MFSK16, which uses 16 different frequencies to represent 4 binary bits in each symbol. By your notation, this would be 16-FSK.
The more frequencies that you use in a symbol, the more complicated your modulation/demodulation circuit. Typical MFSK applications in amateur radio require a computer sound card and CPU for signal processing. Analog circuitry can be developed somewhat easily for FSK using two band-pass filters.
link|improve this answer
feedback
I believe 2-FSK is just an encoding scheme that says:
  • A "one" is encoded by transmitting a sine wave frequency f_1
  • A "zero" is encoded by transmitting a sine wave with frequency f_2
feedback
or
required, but never shown
