I live in the Netherlands and can't recharge my Japanese cellphone because I think it's due to the difference in voltage. What should I use in order to recharge it anyways?
Thanks!!
I live in the Netherlands and can't recharge my Japanese cellphone because I think it's due to the difference in voltage. What should I use in order to recharge it anyways? Thanks!! |
If its a major brand Nokia, SE, Samsung to name a few. Get a local charger and use it, its the safest approach. |
What is the nameplate rating? A lot of newer chargers use PFC, which allows them to work from 85Vac all the way up to 265Vac... |
First you need to check the voltage rating on Japanese cell phone charger. If the rating on the converter is ~110v to ~220v, that means the charger can take 220v as well. All you need is a plug adapter which you can use with existing charger. The plug adapter just allows you to plug-in your charger with square pins to your power socket. If the voltage on the charger is just ~220v, there are two options:
