Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Last week we had very cold weather; and as a result there were lots of frosted pipes (iron and plastic). I spent a lot of time defrosting metal pipes with a torch, but could not do the same with plastic ones.
Could a practical gadget be made to thaw the ice trapped inside metal/plastic pipes based on induction? What would a blueprint of such look like?
share|improve this question
This isn't an electronics based solution, but it sounds like you have problems with your building envelope. The cheapest and easiest solution is usually to fix the problem at the source... Better insulation is clutch! Sometimes just shooting some expanding foam in the right place will take care of it). – RQDQ Jan 15 '11 at 12:36
@RQDQ - Completely agree. – Majid Fouladpour Jan 15 '11 at 12:42
up vote 7 down vote accepted
Induction uses magnetic fields to move free electrons in a regular lattice (ie: a conductor). Ice doesn't have very many free electrons or a regular lattice, so no. It does have a few large ions and protons, but they are at least 1600X more massive, so they don't move much. In this YouTube video, iron filings are dispersed in ice in order to provide a conductive heat sink -- otherwise it would not heat.
An inductive heating device could be used to heat the pipe directly, though.
Something that could heat the ice directly is microwaves. I don't recommend it, however, as there wouldn't be much stopping the energy from bouncing around and heating you!
share|improve this answer
An non-electronic solution to a similar problem in Canada, which is that mobile homes and cottages can have exposed water or waste (sewage) pipes that can freeze in winter. The majority of this piping is plastic now.
The most common approach is to use a thermostat controlled electric heat "tape", which has a waterproof coated heating element (high resistance wire, such as used in electric blankets) which is based on Joule heating rather than induction.
Ad-hoc solutions could include using hair dyers or heat lamps. Even incandescent light bulbs could be used.
How about a good old fashioned heating blanket? That would use electricity to get hot without having to fish heating coils either in or around the pipe and wouldn’t be as dangerous as playing with a microwave’s magnetron.
Induction from a standard electromagnet wouldn't be able to cause normal water to get hot. If you had something of high enough frequency such as a magnetron you would be able to use dielectric heating to slowly melt the water.
Induction can thaw ice if metal were dissolved in the water, so say you had the water pass through a metal filter that allowed the water to pick up some metal particles then you could. With a metal pipe you can simply heat the pipe with induction pretty efficiently.
It would look like a thick coil of wire.
youtube.com/watch?v=aLwaPP9cxT4 <-- example of melting ice with metal particles in it. – Alan Ball Jan 15 '11 at 7:47
Just realized a fast, way of going about it would be to pass a wire through the pipe, and to put the induction coils over the pipeline. – Alan Ball Jan 15 '11 at 7:51
In response, if you do go the microwave route, please wear metal protection over your eyes, some kind of screen. Microwaves cause instant blindness even with your eyes closed, they cause cataracts to form. Please be careful. – Alan Ball Jan 15 '11 at 7:54
@Allan Ball - Unfortunately passing a wire through the pipe is not practical. Also, the microwave method, as you and tyblu say, is a safety hazard. – Majid Fouladpour Jan 15 '11 at 9:14
The melting point of ice is somewhat lower than that of plastic - all you need to do is use hot air with a controlled temperature. Like a hairdryer or fan-heater. Or hot water.
For just below freezing ambient temperatures, constantly flowing cold water (e.g. 4-10 C [40-50F]) will actually work too. That is why cold water pipes most often burst while people are away, the cold water is still long enough to cool to freezing. – mctylr Jan 17 '11 at 0:43
Would microwave work? It would be safe on plastics while heating the water as it does with food in a microwave.
Yes, microwaves would work. The issue is that without shielding, high power microwaves are dangerous. It would be difficult to shield a device that beamed into a pipe, but I don't think it would be impossible. – tyblu Jan 16 '11 at 21:01
discard
