I have a bunch of defunct arduino boards that I'm trying to restore - Arduino Uno with ATmega328p chips. They do not respond to the usual flashing commands, so I'm trying to flash via the arduino ICSP headers, through an intermediate bus pirate.
The process fails due to an invalid signature, like so:
$ avrdude -c buspirate -P /dev/buspirate -p m328p -v -F
avrdude: Version 6.0.1, compiled on Sep 21 2013 at 11:40:49
Using Port : /dev/buspirate
Using Programmer : buspirate
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : BusPirate
Description : The Bus Pirate
Attempting to initiate BusPirate binary mode...
BusPirate binmode version: 1
BusPirate SPI version: 1
avrdude: Paged flash write enabled.
AVR Extended Commands not found.
avrdude: initialization failed, rc=-2
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x881608
avrdude: Expected signature for ATmega328P is 1E 95 0F
BusPirate is back in the text mode
avrdude done. Thank you.
(this is just running -v
but trying to set fuses or flash fails the same way)
Weird thing is that the device signature changes slightly on each attempt, so something is definitely not behaving correctly.
I tried the same process by hooking up to the atmega328p pins directly (and not via arduino board ICSP header pins), but with no success.
Is there any salvaging the atmega328p or is it beyond repair?
-F
from your command. I'm curious where theavrdude: initialization failed, rc=-2
came from. \$\endgroup\$avrdude -p m328p -c puspirate -P /dev/buspirate -U signature:r:/dev/stdout:i
? It reads the signature from the AVR. Are you sure buspirate doesn't take a-b
for baudrate? \$\endgroup\$-x ascii
. BinMode is supported in firmware 2.7 and newer, older FW's either don't have BinMode or their BinMode is buggy. \$\endgroup\$
