Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I would like to know two things that is making my head quite confusing these days.
If i allocate an int in C18 compiler I know it will take two bytes and, if I initialize a pointer to the variable, say:
int x,*xptr;
xptr = &x;
then I have to access *xptr for first byte and *xptr+1 for the second byte?
Well, what factor determines that which one is MSB and LSB?
share|improve this question
The question is not related to electrical engineering, this should have been posted in stack overflow – alexan_e Dec 10 '13 at 8:00
up vote 8 down vote accepted
The order is defined by the compiler. If you look at the MPLAB C18 C Compiler User's Guide and search for "endianness" on page 12 you'll find:
Endianness refers to the ordering of bytes in a multi-byte value. MPLAB C18 stores data in little-endian format. Bytes at lower addresses have lower significance (the value is stored “little-end-first”).
So in your example *xptr will reference the LSB and *xptr+1 will reference the MSB.
share|improve this answer
Thank You @PeterJ – Rookie91 Dec 10 '13 at 4:04
The 'endianness'. Generally speaking - it should not matter.
If you want upper and lower bytes of a word do something like:
unsigned int a = 1234;
unsigned char upper;
unsigned char lower;
upper = (a>>8)&0xFF;
lower = a & 0xFF;
and the reverse:
unsigned char upper = 12;
unsigned char lower = 34;
unsigned int a = 0;
a |= upper;
a <<= 8;
a |= lower;
This will ensure your code works reguardless of the compiler/cpu/endian.
That is not good coding practice on an embedded system - the compiler is all too likely to do exactly what you have told it to and implement some very expensive (in terms of time & processor cycles) operations. Much better to do as the OP originally suggested. – markt Dec 10 '13 at 6:03
It would be a very poor compiler indeed that did not convert multiplication and division by 256 into left and right shift operations. However, I agree that this is poor coding practice. If your intention is to shift bits then use a shift operation. If your intention is to merge bit fields then use an OR operation, not an addition. – Joe Hass Dec 10 '13 at 12:12
I think you are missing the point. It isn't over mul add vs shift/or, its about not assuming endian. I could re-write it with shift/or of course. Once people assume endian, then they start doing things like... assume padding alignment etc. – Myforwik Dec 15 '13 at 2:20
discard
