Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I've seen these stacked-disc structures on high voltage power lines everywhere. I could not find any information regarding this particular shape, though.
Insulator on Railways (From Wikimedia Commons)
From what I've noticed, high voltage ceramic insulators only insulate conductors end-to-end (not inside to outside, like traditional plastic insulators). I can only assume the shape makes it difficult for an electric arc to travel along the ceramic material, as opposed to, say, along a solid cylindrical piece.
Why exactly are ceramic insulators shaped like that? Is it to reduce cost? Thermal concerns (from possible electric arcs)?
share|improve this question
up vote 7 down vote accepted
Electricity can more easily travel across a surface of an insulator. If the surface is made longer it makes the surface path longer and thus is able to withstand higher voltages before breaking down.
share|improve this answer
Plus the shape is intended to ensure at least part of the "cup" stays dry in most normal weather; water tends to reduce the surface impedance. – Brian Drummond Dec 28 '13 at 10:23
@BrianDrummond Indeed, imagine if it was a smooth, ceramic cylinder. In heavy rain, a rivulet of water could easily run along its length between the two terminals. – Kaz Dec 28 '13 at 15:52
discard
