Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Sometimes when I order PCBs from a board house, I omit the bottom silkscreen for budgetary reasons. When I place surface-mount chips on the bottom of the board, I then end up with a footprint that doesn't indicate the chip orientation. This is annoying because it means that I need to verify the component placement and orientation during assembly, and this allows for errors when placing the parts.
How can I clearly indicate pin 1 with the remaining layers in a way that will be clear but not significantly impact the PCB size or cause issues when soldering? I'm assuming that I always have access to a solder mask layer and a copper layer.
share|improve this question
You might be doing onesy-twosy builds. But if you are doing any volume at all, then doing double-sided SMT is probably a bigger cost adder than a second silkscreen layer. – The Photon Jan 2 '14 at 17:32
@ThePhoton This is purely for one-off builds that will be hand assembled. I understand the cost trade-offs change when you start talking about automated manufacturing. – W5VO Jan 2 '14 at 17:40
up vote 30 down vote accepted
Have a differently shaped solder mask on pin 1.
For surface mount processors, you could have the pin 1 pad be noticably longer than the others.
share|improve this answer
7
I've also seen (and it's built in to the supplied libraries in Altium) pad 1 have rounded corners (in copper) while all the others are rectangular. – The Photon Jan 2 '14 at 17:29
I add a small dot in the copper layer near pin 1 but if the routing is too dense it may not be possible
alexan_e - Look at your profile - you may wish to save an image of your reputation before the year gets much older - It looks like this :-) – Russell McMahon Jan 3 '14 at 11:07
@RussellMcMahon I haven't realized it, thank you for sharing. Now there is only stevenh standing in the way for a full house...maybe next year LOL :-) – alexan_e Jan 3 '14 at 11:28
Unless there are tight tolerances for the pad layout use a different shape pad for pin 1. i.e. oval instead of square.
Edit: the difference between this answer and previous answers is the difference between a solder pad and solder mask.
This solution doesn't seem to be different from what Adam has proposed in his reply. – alexan_e Jan 2 '14 at 21:38
I agree with the previous suggestions for altering the pin 1 shape, whether that be in soldermask only, or the pin as a whole (Soldermask & Copper).
However, for aiding with the always inevitable debugging and troubleshooting later-on, pin shape & component pin 1 markings may be difficult to identify. It may be preferable to use a small "fiducial-like" marking on the board to emulate silkscreen. This will simply be a small copper marking (dot or line) with a soldermask opening over it.
Another idea may be to align all your components to have their Pin #1 in a specific orientation (usually handy for polarized 2-pin SMT devices, diodes, caps etc.)
discard
