Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
On my amp, I have a big round knob, that I can turn forever in both directions, to control volume. It simply turns up whenever I turn clockwise and down when I turn counter clockwise. There is no limit as to how far I can keep turning it.
How do I create this in my own project? I have an arduino where I want a knob like this, to control a value in the arduino memory. Simply, turning up, add to value, turning down, subtract from value.
I assume I need some kind of potentiometer, but they do not turn forever, do they?
share|improve this question
Actually there are potentiometers, usually with two wipers, that do turn forever. However, those are not approriate for what you are asking about. – Olin Lathrop Jan 4 '14 at 16:37
up vote 10 down vote accepted
What you need in a rotary encoder, they have two outputs that generate pulses which are then decoded to read the direction of rotation.
Rotary mechanical encoder Rotary mechanical encoder waveform
Refer to http://playground.arduino.cc/Main/RotaryEncoders
To control the volume you can use Arduino to drive a volume control chip like PGA2311.
There are even 4 channel versions like PGA4311
You can also control digital potentiometers like MCP41xxx/42xxx
share|improve this answer
@DiegoCNascimento I suggest not to link Arduino directly with the answer The OP asked specifically for Arduino so why including an Arduino link with a library for his needs is wrong? – alexan_e Jan 4 '14 at 19:17
ops, have not read that, sorry :) – Diego C Nascimento Jan 5 '14 at 0:12
discard
