Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I bought some text LCD modules without spec sheets or obvious part numbers. They all have a series of connector pins, unlabelled other than a 1 to indicate pin 1. I was able to get the one with a Hitachi driver and 16 pins to work fine, and now I'm trying to get a 9-pin lcd to work.
Is there a standard pinout for most 9-pin LCDs?
Pin 8 is clearly A for anode, possibly for backlight. Pin 9 is K for cathode, again possibly for backlight. The other 7 pins are unlabelled besides the 1 and 9 indicating pin numbering.
There is a sticker on the back that reads:
UC164904
-GLHTX-A
97051306
And another that says 847845740. There is a Samsung logo as well. The controller circuit is covered with that hard black protective material that I typically see on cheap devices, so I can't see the controller at all.
If the faint outline I can see on the screen is right, it looks like its 16 columns x 4 rows.
share|improve this question
The black lump on the back of the display module is most likely covering the display controller chip and not a general MCU. – Michael Karas Jan 7 '14 at 11:27
@MichaelKaras Right. Edited the post, as I meant the display controller. – mouseas Jan 7 '14 at 19:48
A search for UC164904 lead to this page which shows a 20x4 SPI LCD
share|improve this answer
That looks like it has 1 data pin instead of 4 or 8 like the standard 16-pin lcds. I'm guessing Arduino's LiquidCrystal library won't work with that as-is? – mouseas Jan 7 '14 at 20:00
@mouseas This is a new question so you shouldn't add it as a comment to an answer. alexan_e was kind enough to search for your LCD's part number for you but you shouldn't assume that alexan_e is also familiar with Arduino libraries. The best approach is to open a new question and give it an Arduino tag. That's also more helpful to other visitors to EE.SE. – Joe Hass Jan 7 '14 at 21:05
@mouseas The SPI protocol has two data pins (MISO/MOSI), one clock (SCLK) plus one chip select (CS). As joe suspects I'm not familiar with arduino since I code using avrstudio but if your library is meant to be used with the classic 4/8bit data lines then it will not work unless you modify it. – alexan_e Jan 7 '14 at 21:20
Just knowing that it is set up for SPI protocol helps a ton. Thanks! – mouseas Jan 8 '14 at 17:09
discard
