Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
The general wisdom is that it is better to only ever use channels 1, 6, and 11 as they are the only three non-overlapping channels for 2.4ghz wifi (in the US), and two adjacent networks on the same channel would perform better than two adjacent networks on different (but overlapping) channels.
So then, why would the IEEE even allow for 11 channels in the specification? Is there any possible use case where it would be desirable to use one of the in-between channels? Even if you were completely isolated from other networks, it wouldn't make sense to use other channels because you would then be limited to only two, rather than three non overlapping channels/access points.
I have read many articles explaining why its better to stick with 1, 6, and 11, but I have yet to come across any explanation for why they didn't just make three channels to begin with (1, 2 and 3 mapping to 1, 6, and 11 respectively).
share|improve this question
I was wondering the same once actually. – Dzarda Jan 31 '14 at 16:28
I've heard a theory that aliens use those "spare" channels for communicating with each other. I know it's a sensible question but I couldn't help myself, sorry... I have upvoted the question because it would be cool to hear a real reason. – Andy aka Jan 31 '14 at 17:56
up vote 4 down vote accepted
802.11 specifies operation in the 2.4 GHz band. This is one of the industrial, scientific and medical (ISM) radio bands, which are used for quite a lot more than Wi-Fi. The ISM bands were in fact allocated for non-telecommunications use, where devices that must necessarily spew RF interference may do so. In the US Wi-Fi gets to operate here under FCC part 15 on the condition that if a Wi-Fi device receives interference, it just has to deal with it. I'm sure other countries likely have similar regulations.
There's no requirement that the other applications in this band (RF process heating, microwave ovens, medical diathermy machines, etc.) will conform to the 802.11 channels. Thus, the ability to move the channel to some degree smaller than the channel width may be useful to avoid interference from or to non-Wi-Fi devices.
It's also worth noting band allocations are not the same in all countries. In some places that aren't North America, it's possible to get three non-overlapping channels on (1, 6, 11), but also (2, 7, 12) or (3, 8, 13).
share|improve this answer
The issue isn't just interference from non-WiFi devices, but also interference to them. An analog 2.4GHz video transmitter might "work" even when a WiFi device happens to use a frequency within its bandwidth, but the picture quality would be degraded. If two such transmitters were being used at different frequencies, it might be possible that a WiFi "channel" of e.g. 4 might avoid clobbering the video on either side, even though 3 or lower would clobber the video below, and 5 or higher would clobber the video above. – supercat Jan 31 '14 at 18:34
Great explanation! And thanks @supercat for pointing out that sometimes its the WiFi interfering with other devices (though not a big concern for most home users). – AndrewH Feb 2 '14 at 4:23
Historical reasons.
The original channel allocation is for 802.11 and 802.11b, which has 11 non-overlapping channels.
The 802.11g standard increases the bandwidth used, which means that channel 1 is really spanning channels -1..3, channel 6 is really spanning channels 4..8, and channel 11 is really spanning channels 9..13, which is the only configuration with three non-overlapping 802.11g channels.
If you were to use channel 9 with 802.11g, this would disturb 802.11b and 802.11g communication on channel 11, and 802.11g traffic on channel 6 (802.11b on channel 6 would be unaffected).
discard
