Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
My third hand damages wires insulation because it's holding them too tight. Any tips how to avoid this?
third hand
share|improve this question
7
Put some heat-shrink on the clips? – Chris Johnson Feb 5 '14 at 12:14
up vote 11 down vote accepted
Wrap the teeth in heat-shrink tubing or electrical tape. It will still hold just as tightly, but without the teeth, the pressure on the wire being held will be less.
share|improve this answer
I like to tightly wrap rubber bands around the back of the clips to take some of the pressure off. That way, you can adjust the pressure to your liking. Sometimes I use the alligator clips to hold a pair of cheap soldering heat sink clips and use those to actually hold more delicate components.
See the heat sink clip in this picture: enter image description here
I have the same tool; I just bent the teeth on the clips inwards using a pair of pliers.
If the O.P. goes the heat shrink route, he'll be able to remove the heat shrink and restore the holder to its original state. Bent teeth are more permanent. – Nick Alexeev May 12 '14 at 23:57
You could also change out the alligator clips for a spring clip instead. I found some small clips similar to this at a hardware store (http://www.homedepot.com/p/HDX-3-4-in-Mini-Spring-Clamp-80001/100656782?MERCH=RV-_-RV_nav_plp_rr-1--NA--100656782-_-N). They still squish the insulation a bit, but at least they don't bite into it like an alligator clip does.
discard
