Im using a op amp as a voltage follower on the front end for my data acquisition card Choose the AD817 amp powered with a 12v single power supply I have a 4v peak to peak signal going into my system The signal im getting on the output of the AD817 seems to be just the positive 2v peak Don't seem to be getting the lower 2v part of the signal
1 Answer
As the datasheet shows, although this is a low-voltage opamp, it is not a rail-to-rail opamp. When powered by +12V and 0V, the output voltage can only swing between +1.5 and +10.5 volts.
Also, if/when the input signal goes below ground, obviously the output can't follow.
