10
I ask this question, just out of curiosity. In this die of 556 IC, what are the wave-like squiggle at the four corners, and two more on the top?
  • \$\begingroup\$ Awesome! We need more semiconductor design questions here. \$\endgroup\$ Commented Mar 25, 2014 at 4:18
10
Those are high-current NPN transistors. Here, from the designer's book:
Those are the large transistors required to drive the output pins: two for each of the totem-pole main outputs and one for each of the open-collector discharge pins. Those transistors need to handle on the order of 200 mA each, so they need to be much larger than the internal analog/logic transistors.
