I plan to create a magnetic vibrator to shake a small container. What I plan is to buy
- Two "Magnet Wire 14 AWG Gauge Enameled Copper 1.5lb 118ft 200C Magnetic Coil Winding"
- a custom made container with two strong magnets on each side, the container will be held by two bearing, so the container can "swing"
- a power resistor (Any suggestion of where I could buy a variable power resistor)
I plan to put the container in middle in two magnetic coils where those two coils and the power resistor are in series. I plan to use power from wall outlet 120V60Hz to create the magnetic field
Any suggestion?
