this question may be pretty simple for some people on this forum. Here's a basic image to go with the question.
(also here)
- Two films of metal, virtually 0 thickness and 2 sheets of plastic. Find the capacitance.
- The assembly is then rolled into a cylinder, estimate its radius. Why does the capacitance approximatly double?
Ok, first of all this is whats i've got so far. I've just used the Er of plastic as 2.
C=(A*E0*Er)/h so (1*0.02*(8.85*10-12)*2)/10-4 = 3.54*10-9F
But would you multiply that by 2 since there are two plastic sheets and two metal parts? Or would you add them in capacitance of them both in series? Also if the metal sheets were thicker and had a realative permitivity how would you find the capacitance in this assembly? Could you multiply the Er of the metal with the Er of the plastic and E0. But what about the new thickness? Essentially this just two dielectrics correct?
now for 2. this where I'm even more confused. the volume of a cylinder \$ \pi r^2 d\$ we could get d. oh, i'm not sure to be honest.
Any help would be greatly appreciated.
Edit. Hang on, there is just one dielectric, the plastic and the metal is just used as a conductor between them. Sorry. Would be interesting to know how to calculate two dielectrics in the capacitor though. I'm thinking you would just need to know whether they were in series or parallel.
