Does anyone manufacture a fiber-coupled diode laser in an SMD package?
Something like this, but smaller.
  • \$\begingroup\$ Questions seeking recommendations for specific products or places to purchase them are off-topic as they are rarely useful to others and quickly obsolete. \$\endgroup\$
    – The Photon
    Commented May 2, 2014 at 0:13
  • \$\begingroup\$ To find a part like that you need to be ready to specify what wavelength laser, what power level, what modulation bandwidth, and what kind of fiber do you want on the output. \$\endgroup\$
    – The Photon
    Commented May 2, 2014 at 0:14
  • \$\begingroup\$ For example, thorlabs.com/newgrouppage9.cfm?objectgroup_id=4190 \$\endgroup\$
    – The Photon
    Commented May 2, 2014 at 0:20
  • \$\begingroup\$ Asking if a specific type of product or form-factor exists is on topic! \$\endgroup\$
    – Passerby
    Commented May 2, 2014 at 0:48
    \$\begingroup\$ @ThePhoton, Thanks, but as Passerby noted, I'm not asking for specific products or places to purchase them: I'm asking whether a particular kind of readymade component exists. I'm not after any specific wavelength, power level, bandwidth or fiber: just a compact form factor. Your link was helpful. Please feel free to make it into an answer :) \$\endgroup\$
    – user2023
    Commented May 2, 2014 at 1:29
The mechanical loads which can be placed on the package by a fiber, along with the general need for considerable waste heat management, make a "pure" SMD package a bad idea. One exception: http://pdf.datasheetcatalog.com/datasheets/70/475162_DS.pdf. You'll notice, though, that this only produces .3 mW, and the fiber is not connectorized. For any diode with more power, you need a physically larger package to dissipate heat, and once you start using a bigger package, SMT is not generally strong enough to reliably mount the part. There are a fair number of modules which are mechanically secured by screws, but with surface mount leads for electrical connection. These are generally (roughly) not much smaller than the unit you dislike.
