I'm helping out in a project to convert an electric rice cooker into a sous vide cooker with a PID control. For those unaware, this is a precision-controlled water bath at "low" temperatures (setpoint at between 50 and 80 degrees Celsius).
The AC load is switched by means of a TRIAC, triggered by a TRIAC optocoupler with zero crossing detection (MOC3063).
I'm sensing temperature using 7 NTCs, distributed in various points of the cooker, all connected to a TI LMP90079 A/D converter. This part has a few fixed sample rates, and the one I'm thinking of using is 6.71 Hz. Actually, due to differences in the crystal frequency and the use of a calibration mode available in the part, there may be a very slight (~0.2%) discrepancy to this nominal rate. Since I sample 7 channels at a time, my sampling rate is divided by 7, so it's approximately 0.959 Hz, which is the rate at which I run my PID loop.
My initial plan for actuating the rice cooker's heating element was to generate a 1 Hz PWM wave that is input to the TRIAC optocoupler. The duty cycle would be given by the controller output obtained from the PID loop. Each time the PID loop is run, I would update the duty cycle.
At this point, it occurred to me that I could feed the controller output to a delta-sigma modulator, but first resampling the controller output signal to a frequency of 120 Hz (since I'm using a TRIAC optocoupler with zero-crossing and there are 120 semicycles in a 60 Hz mains waveform.) The output of the delta-sigma modulator would be used to actuate the TRIAC, synchronized to the zero-crossings of the mains waveform.
A sigma-delta modulator requires a low pass filter to be applied to the output of the modulator, but my reasoning is that the physical system itself serves as a low-pass filter: The rice cooker has a capacity of 4.5 liters/1.2 US gallons of water, and a 700 W heating element, which means I need at least 27 seconds to heat the contents of the cooker by 1 degree Celsius.
So here's what I'm wondering:
- Is this idea fundamentally sound?
- What's the equivalent number of bits of this DAC? For the 1 Hz PWM waveform solution that I was previously going with, I reckon accuracy is ~7 bits since I can choose between 0 to 120 semicycles for each 1-second period, and log_2 120 ~ 7. As for the sigma-delta DAC, according to this Maxim application note, using a second order modulator with 128x oversampling (120/0.959 ~ 125 so that's close), I should expect a 90-95 dB SNR, which works out to ~15-16 bits of resolution. Is this correct?
- That said, should I expect to see any kind of real-world improvement if I used this sigma-delta DAC, compared to the original 1 Hz PWM waveform solution?
- Is a second order sigma-delta modulator a good choice? The ADC that's reading out data from the NTCs has a 16-bit ENOB and noise free resolution at the choice of PGA gain and sampling rate that I'm going to use. From my calculation above, I'm getting out the same resolution from the DAC using a second-order modulator, so anything above that would be overkill, in my understanding.
- There is no integer oversampling factor that takes me from the 0.959 Hz sampling rate to a 120 Hz sampling rate exactly. So say I get to a 119.8 Hz rate; then there will be a beat frequency of 0.2 Hz between the mains waveform and my waveform. What effect will this have on the accuracy of the conversion process?
I'm aware that I could use a non-zero-crossing TRIAC optocoupler to perform phase control of the AC waveform, but I'm doing this as an intellectual exercise, so I'd like to pretend that solution is not available.
