im having a bit of trouble with the following circuit. i am using an LED to shine light onto our finger and reflect onto an LDR (RD). the LDR is the source of the signal. the voltage input is in the 20mV range and the amplification should be 100 times to get it up to 2V. however we are getting no amplification and filtering is also not working. we are currently using a high pass filter followed by a 2 stage low pass filter.
LDR characteristics: - Dark resistance: 0.5M ohm min. - Light resistance: 2.8K ohm min 8.4K ohm max
