I am trying to re-implement the BCD to 7-SEGMENT converter by hand. So, I have came up with the following truth table:
I have the following minimization created with the Karnaugh map. Is there any way to minimize this more?
  • \$\begingroup\$ Are you trying to minimize terms or gates? \$\endgroup\$ Commented Jun 6, 2014 at 7:03
  • \$\begingroup\$ gates and terms if possible \$\endgroup\$
    – Victor
    Commented Jun 6, 2014 at 7:34
Invert it. Inverted logic often gives better results if there are more 1's than 0's.
When minimising gates also group similar subexpressions so they can share gates.
$$a = \overline{\overline{ABC}D + \overline{A}B\overline{CD} + A\overline{B}CD + AB\overline{C}D}\\ = \overline{\overline{AC}(\overline{B}D+B\overline{D}) + AD(\overline{B}C+B\overline{C})}\\ =[A+C+(B+\overline{D})(\overline{B}+D)][\overline{A}+\overline{D}+(B+\overline{C})(\overline{B}+C)]\\ =(A+C+\overline{BD}+BD)(\overline{A}+\overline{D}+\overline{BC}+BC)\\ =(A+C+\overline{B\oplus D})(\overline{A}+\overline{D}+\overline{B\oplus C})$$
  • \$\begingroup\$ but it doesn't work... below is a link to my circuit. the probe stays always on. imgur.com/mIW1kh7 \$\endgroup\$
    – Victor
    Commented Jun 6, 2014 at 17:23
  • \$\begingroup\$ Your circuit have several errors so it does not work. Upper XOR/OR is $A+\overline{C}+B\oplus D$ instead of $A+C+\overline{B\oplus D}$. \$\endgroup\$
    – Vovanium
    Commented Jun 9, 2014 at 11:34
