From the step response plot, the peak overshoot, defined as
$$M_p = \frac{y_{\text{peak}}-y_{\text{steady-state}}}{y_{\text{steady-state}}}\approx\frac{1.25-0.92}{0.92}=0.3587$$
Also, the relationship between \$M_p\$ and damping ratio \$\zeta\$ (\$0\leq\zeta<1\$) is given by:
$$M_p=e^\frac{-\pi\zeta}{\sqrt{1-\zeta^2}}$$
Or, in terms of \$\zeta\$:
$$\zeta=\sqrt{\frac{\ln^2M_p}{\ln^2M_p+\pi^2}}$$
So, replacing that estimated \$M_p\$:
$$\zeta\approx0.31$$
Also, from the step response plot, the damped natural frequency is aoprox. 0.5 Hz or \$\pi\$ rad/s. The relationship with the undamped natural frequency is:
$$\omega_n=\frac{\omega_d}{\sqrt{1-\zeta^2}}\approx3.3\text{ rad/s}$$
Finally, the gain \$G_{DC}=y_{\text{steady-state}}\approx0.92\$
A standard second order transfer function has the form:
$$H(s)=G_{DC}\frac{\omega_n^2}{s^2+2\zeta\omega_ns+\omega_n^2}$$
Putting the obtained values:
$$H(s)\approx\frac{10}{s^2+2s+11}$$
Compare the step response below with that supplied by you:
