I've been working my darnedest over the past few weeks learning more and more about amplifiers, BJTs and various topologies. As I go through Art of Electronics, I try out everything mentioned in at the very least (P)Spice.
I've run into a conundrum. When I make a class-B output stage, as the following: Schematic 1
Everything is kosher, and I get this output from a 3Vp sine wave:
Output waveform
If I replace the signal source with something more practical, like a VAS, as such:
It doesn't work out the same. I end up getting this:
Where the negative half of the waveform appears to be rectified. I notice that it appears to go to some positive DC value too, I suspect that is around the value of a diode drop, but I am not sure why. I have spent several hours trying to find an explanation for this, and what's worse, is that the circuit is almost verbatim out of the book.
If I put a DC offset on the signal, the "rectified" waveform becomes proportionally smaller, that is, with a +/-2VDC offset, I'll have alternating half-cycles of ~5V and ~1V. I've played around with resistor values to get a feel for their effect, but that again doesn't seem to help.
As I'm really trying to understand this to the point maybe in the future I can not only understand amp designs but make my own, I'd really appreciate any help in understanding what's going on. Is something wrong with my design? How can I make it work as intended, i.e., get a proper, proportional sine wave output?
My source is a sine wave, 1kHz, 3Vp, 0VDC. This is taken from Art of Electronics, Fig 2.66.
Update: I think I may understand now, it was my rather whimsical selection of resistor values. I've updated the schematic, as well as given all the components much nicer names:
new Schematic
The issue before, as mentioned, was that because of my biasing, the collector "had nowhere to go" (I like how that was put). Essentially, as I understand, the positive part of the waveform "comes" from resistor R1, and the negative part "comes" from VCE. Now that I've biased it so that VCE has at least ~ 7V to its name, the PNP can actually do its job. Furthermore, everything is forward biased. The only question I still don't fully understand is why it "rectified."
Here's a print of the new input/output:
I took the input from Rg as the high-pass formed by Cb/Rg does attenuate somewhat - I chose a rather small value for Cb so that I don't have to do print delays on the output while it charges (:/). I do understand a much larger cap would be necessary to pass the full 20-20kHz.
  • \$\begingroup\$ Scratch that - on the positive waveform, the base is more positive than the collector and throws it into saturation. I understand about the biasing now. But then how was this circuit supposed to work in the first place? I built it as the author drew it \$\endgroup\$
    – MJXS
    Commented Jul 8, 2014 at 0:46
  • \$\begingroup\$ Bias the stage properly and AC couple into it. (Or level shift but AC coupling is a simpler place to start) \$\endgroup\$
    – user16324
    Commented Jul 8, 2014 at 9:19
  • \$\begingroup\$ What is a "VAS" source? It seems this is something specific to your simulation software. Use simulations if you want, but the question should stay about the electronics (unless it's a question specifically about simulation, which this isn't). \$\endgroup\$ Commented Jul 8, 2014 at 11:51
  • \$\begingroup\$ VAS = voltage amplification stage. Sorry for the confusion. \$\endgroup\$
    – MJXS
    Commented Jul 8, 2014 at 14:27
4 Answers 4
There are two problems:
1) The first stage can only work properly at base voltages below zero. When the collector-base junction is reverse-biased, i.e. in normal operation mode, the the total voltage drop on R67 and R62 equals that on R56 (there is a small difference, which we can ignore here). This value can't be more than about 11 V, as the total voltage drop on all of these resistors, diodes and the transistor is 24 V. When when the base voltage is anywhere from slightly below zero to positive, the collector doesn't have anywhere to go, so to speak, it cuts off.
2) floating input, and we don't know anything about your source.
You may want to use an emitter follower with a diode bias, or two emitter followers in series, npn and pnp.
  • \$\begingroup\$ Hi there - My source is a sine wave, 1kHz, 3Vp, 0VDC. Also added this to the information above. Is the circuit wrong, or am I just misusing it? (I've taken it near verbatim from AoE) \$\endgroup\$
    – MJXS
    Commented Jul 8, 2014 at 0:37
  • \$\begingroup\$ "The first stage can only work properly at base voltages below zero." Egad I think I'm starting to understand. So is this circuit as it was just defective then? \$\endgroup\$
    – MJXS
    Commented Jul 8, 2014 at 0:38
  • \$\begingroup\$ I guess one could say you're misusing it. Where in AoE did you find it? \$\endgroup\$ Commented Jul 8, 2014 at 0:52
  • \$\begingroup\$ I am indeed misusing it. I've adjusted the resistor values and now I finally understand better how it works. Figs 2.57 thru 2.66 essentially. \$\endgroup\$
    – MJXS
    Commented Jul 8, 2014 at 1:06
  • \$\begingroup\$ This is not a good circuit for what you're trying to do. It may work right now with the adjusted values, but the DC offset will drift. What's keeping the base voltage of Q1 at -6.654 V? The voltage drop on Rg, which is proportional to base current, which depends on Q1's beta, which, in turn, depends on temperature. And the output range is still far from ideal. \$\endgroup\$ Commented Jul 8, 2014 at 2:56
If you want a VAS stage, you need to make one. As it stands, the collector of Q20 is not a voltage output, it's a current sink. Try adding a 1k resistor from +12 to the collector of Q2.
You also now have a DC offset, but that's what biasing is for.
  • \$\begingroup\$ I swear I tried this before. I see the difference though. A couple of questions if I may: a) Is the circuit incorrect then, or am I misusing it? b) Why is the DC offset necessary? The whole goal of this was to make an output that is centered at 0VDC. c) How do I achieve what I mentioned in b)? Sorry if my questions are really basic, some of this is a little hard to wrap my head around. \$\endgroup\$
    – MJXS
    Commented Jul 8, 2014 at 0:17
I might add some to this - a transistor is NEVER a voltage amplifying part, it is a current amplifier. From this knowledge you must start when desingning with BJTs. At best, such as a MOSFET or JFET, they are voltage to current translators. But never voltage amplifiers. Tp understand - first analalyze the current transfers and then relate them to the resistive or inductive load.
R2(R56) should be very low (maybe zero) or Q1/Q20 will never be able to drive the output stage negative.
You will need to bias the VAS so that the output is ~zero when there is no signal. Typically this is done with DC feedback from the output to a differential input stage.
To get full swing positive it is common to bootstrap R42 with a capacitor from the output.
In addition all amplifiers of this type will have overall negative feedback from the output to the input of the differential input stage. Usually this uses the same path as the DC feedback for bias but arranged so the AC gain is 10-100 but the DC gain is unity.
