Are there any layout requirements/special considerations when routing traces on top and bottom layers of a double sided PCB, e.g. angle between traces, can traces pass beneath an IC, etc?
I know that ground/signal planes should have the same boundaries on top and bottom in order to avoid unwanted capacitances which may add noise. But are there similar restriction to the traces?
