Hopefully this question isn't too novicelike:
I have an LCD (BC1202A) that I want to drive from a parallax propeller board.
Spec data:link1 and link2
After hours of mucking around (mis-wiring, contrast pin disconnected, wrong resistance on the contrast, trying to drive it with 3.3v instead of 5v, etc.) I finally got an LCD test program to work. Yay.
But I cannot for the life of me get the backlight to work.
Per the sheet this is supposed to be driven by pin 15, and from looking around that's apparently the normal way of doing it. (Some LCDs seem to have a pin 16 which is the ground for the backlight, this LCD doesn't.) It also talks about options to use pins 1 and 2 (which are already what are powering the regular LCD operation) and something about "A" and "K".
In any case, all of the examples I see when searching around are for the pin 15 mode. Sounds good to me. So then I look at page 13 of that second spec sheet above and it says:
 LED B/L drive from pin15 (LED+)
Okay, so I connect pin 15 to the + (5v). (I assume that's what that means) Tried that, does nothing. Tried connecting to minus/ground - nothing.
It also has option b:
(Option) LED B/L drive from pin1 (Vss) pin2 (Vdd)
(1) Jump 1,2 Short
(2) Current Resistor required on RL
(3) Jump 15 open
(4)To be sure of enough current supply for both Vdd + LED B/L
I don't totally follow their shorthand here - but it seems to me that they are saying 1 and 2 are usual (ground and + respectively, with a resistor on 2?; tried 1kohm just for kicks, doesn't change anything), 15 is disconnected and make sure there's at least 42mA available (2 for the logic, 40 for the backlight - should not be a problem).
Specific questions:
  • In either option (a) or (b) is there something obvious that I'm not understanding about how they are saying to hook it up?
  • Maybe I fried the backlight by hooking it up wrong - is that possible/likely?
  • Any other ideas of where I might be going off here?
I'm either missing something obvious or this backlight really just doesn't work.
EDIT:
Here is what the thing looks like:
BC1202A BC1202A Front
Which version of backlight do you have? There are 4 versions: LED edge yellow/green, LED array yellow/green, LED edge white/blue, EL / white(blue). It depedns on that. Edit: Look at page 3, numbering system to make sure.
The option b shorthand is: you have some jumpers on the module, you can short jumpers 1 and 2 and open jumper 15 to connect the backlight to the module's power supply via RL (which needs to be changed to an appropriate value). The jumpers most likely are solder joints.
Things change a lot if your backlight is version EL white or blue, because EL needs a high voltage generator (110Vac 400Hz).
  • \$\begingroup\$ Thanks for the reply and the explanation on option (b). Unfortunately it's not clear either which kind I have. (See picture added to post above.) As you point out, on page 3 of the sheet it gives the numbering system, but the letter "J" would be backlight type and I don't see that listed. \$\endgroup\$
    – bgp
    Commented Aug 23, 2014 at 4:37
  • \$\begingroup\$ I see the A/K holes have nothing soldered on. Right there is the place where usually the backlight is connected. I wonder if your display has any backlight at all. Can you provide a front side picture? \$\endgroup\$
    – ceteras
    Commented Aug 25, 2014 at 8:54
  • \$\begingroup\$ Gotcha - yeah I would suspect the same but I'm not really sure what I'm looking for. Front picture added to OP. \$\endgroup\$
    – bgp
    Commented Aug 25, 2014 at 17:29
  • \$\begingroup\$ Usually the backlight system is visible just right of the lcd panel, where the 4 holes are visible. Check if there's anything beneath the lcd panel, between the lcd and the pcb board. \$\endgroup\$
    – ceteras
    Commented Aug 26, 2014 at 8:22
