6
I'm looking for a very low cost barometric pressure sensor. The SCP1000-D01 available at Sparkfun and elsewhere is around $25 but I was hoping to find something in the $5-10 range. I am only interested in rough relative pressure change, so it does not have to have high precision or be calibrated. Basically something like the thermistor equivalent for pressure...
  • \$\begingroup\$ tough question! -- i'll ask around at work when I get a chance -- there's some Japanese company that makes some pressure sensors that are low cost.... although it could be that they are just low cost in high volumes. \$\endgroup\$
    – Jason S
    Commented Dec 29, 2009 at 1:02
  • \$\begingroup\$ I just had this exact same question! \$\endgroup\$
    – vicatcu
    Commented Jan 18, 2011 at 3:07
5 Answers 5
Futurlec has a few barometric sensor in the $5-10 range. These use I2C interface though, so a bit more involved in the MCU side than a simple analog voltage.
http://www.futurlec.com/Pressure_Sensors.shtml
If you're in Australia, you can buy from their Australian website as well.
I would take a look at the sensors from Freescale. I bought an MPX4115A from Mouser.com for about $10. This is (supposedly) suitable for use as an altimeter; I haven't gotten to that project, yet. :-)
You can check out the Bosch Sensortec BMP085 sensor. It is SMT, but it gave me good results.
  • \$\begingroup\$ I still have some - so if anybody is interested - hit the contact button on my site ;) \$\endgroup\$ Commented Jan 8, 2010 at 7:42
  • \$\begingroup\$ BMP085 is good if you don't need anything too high resolution. \$\endgroup\$
    – BrianV
    Commented Jan 13, 2012 at 15:18
Those Freescale devices are very easy to use - I'd interface it to a small MCU with an ADC. Alternatively, you could just connect it to a voltmeter.
Another vote for the MPX4115 family - I'm using one, they're very simple to use & cheap.
