I'm trying to interface an mcu (tm4c123) with external SPI flash memory SST25VF010A. I execute the Read-ID instruction, but instead of gettting BF and 49 (manufacturer and device ids) - I get BC and 41.
Reading the status register also gives weird results - on startup I get 0x8 and after executing the write enable instruction, I get 0xC. Looking at the datasheet and boot up values, I would expect it to be more like the opposite - 0xC on startup and perhaps 0x0 after write enable...
Here is my code:
void ConfigureSPIFlash()
    MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
    MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI1);
    // Enable pin PD2 for SSI1 SSI1RX
    MAP_GPIOPinConfigure(GPIO_PD2_SSI1RX);
    MAP_GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_2);
    // Enable pin PD0 for SSI1 SSI1CLK
    MAP_GPIOPinConfigure(GPIO_PD0_SSI1CLK);
    MAP_GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_0);
    // Enable pin PD1 for Chip Enable
    MAP_GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE, GPIO_PIN_1);
    MAP_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_1, GPIO_PIN_1);
    // Enable pin PD3 for SSI1 SSI1TX
    MAP_GPIOPinConfigure(GPIO_PD3_SSI1TX);
    MAP_GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_3);
    MAP_SSIConfigSetExpClk(SSI1_BASE, MAP_SysCtlClockGet(), SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 125000, 8);
    MAP_SSIEnable(SSI1_BASE);
    uint32_t r;
    while(SSIDataGetNonBlocking(SSI1_BASE, &r)){}
unsigned char SPI_transmit(unsigned char data)
    SSIDataPut(SSI1_BASE, data);
    uint32_t r;
    SSIDataGet(SSI1_BASE, &r);
    return (unsigned char)r;
void main(void)
    ROM_FPUEnable();
    ROM_FPULazyStackingEnable();
    SysCtlClockSet(SYSCTL_SYSDIV_4| SYSCTL_USE_PLL | SYSCTL_XTAL_16MHZ |SYSCTL_OSC_MAIN);
    ConfigureUART();
    ConfigureSPIFlash();
    UARTprintf("spi flash ready\n");
    uint8_t res;
    // send Read-ID command
    GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_1, ~GPIO_PIN_1); // CE low
    SPI_transmit(0x90);
    SPI_transmit(0x00);
    SPI_transmit(0x00);
    SPI_transmit(0x01);
    // get response
    res = SPI_transmit(0xff);
    UARTprintf("received: 0x%x\n", res);
    GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_1, GPIO_PIN_1);  // CE high
Any idea what I'm doing wrong? Thanks!
  • \$\begingroup\$ My first suspect would be an incorrect SPI mode; try clocking data in on falling edges rather than rising, or vice versa. Also, get a scope or logic analyser on the signals to make sure that they're doing what you intended at the physical layer. \$\endgroup\$
    – markt
    Commented Nov 22, 2014 at 12:14
  • \$\begingroup\$ Thanks, in the datasheet it says mode 0 and mode 3 are supported - tried both - still the same result. Other modes don't return any data. I'm also checking with an analyzer - the signals look ok to me... Could it be because I'm using an smd adapter like this: mcumall.com/support/… I'll try soldering the chip, to see if it makes any difference... \$\endgroup\$
    – LachoTomov
    Commented Nov 22, 2014 at 12:29
It turns out that my cheap junky logic analyzer was putting some noise on the MISO line, so the received data gets slightly shifted. When I unplugged its MISO line - the data is now fine. Truly unbelievable...
  • \$\begingroup\$ What logic analyzer should we avoid? :-) \$\endgroup\$
    – m.Alin
    Commented Feb 22, 2015 at 11:28
  • \$\begingroup\$ @m.Alin well since I'm no expert, I wouldn't like to place a blame on the company without being 100% sure it's really the LA :) Could be also the breadboard probably... But it's a very cheap analyzer, not a real/professional one, made mostly for learning purposes :) \$\endgroup\$
    – LachoTomov
    Commented Feb 23, 2015 at 12:22
