Not with only the standard AND
, OR
, and NOT
gates. For the two-bit adder that takes in two-bit numbers AB
and CD
, and outputs a three-bit number XYZ
, the truth table looks like this:
A B C D | X Y Z
0 0 0 0 | 0 0 0
0 0 0 1 | 0 0 1
0 0 1 0 | 0 1 0
0 0 1 1 | 0 1 1
0 1 0 0 | 0 0 1
0 1 0 1 | 0 1 0
0 1 1 0 | 0 1 1
0 1 1 1 | 1 0 0
1 0 0 0 | 0 1 0
1 0 0 1 | 0 1 1
1 0 1 0 | 1 0 0
1 0 1 1 | 1 0 1
1 1 0 0 | 0 1 1
1 1 0 1 | 1 0 0
1 1 1 0 | 1 0 1
1 1 1 1 | 1 1 0
The Karnaugh map for Y
looks like this:
CD AB>
V 00 01 11 10
00 0 0 1 1
01 0 1 0 1
11 1 0 1 0
10 1 1 0 0
The problem is that since you are only allowed two gate delays, and we need both of those: one to AND
together the bits in each group, and another to then OR
those groups together. This means that the groups we can specify are limited to those that do not contain any NOT
s, i.e. only the following:
A B C D A*B A*C A*D B*C
. . x x . x x . . . . . . . . . . . x . . . . . . . . . . . . .
. . x x . x x . . . . . x x x x . . x . . . . . . . x x . . . .
. . x x . x x . x x x x x x x x . . x . . . x x . . x x . x x .
. . x x . x x . x x x x . . . . . . x . . . x x . . . . . x x .
B*D C*D A*B*C A*B*D A*C*D B*C*D A*B*C*D True
. . . . . . . . . . . . . . . . . . . . . . . . . . . . x x x x
. x x . . . . . . . . . . . x . . . . . . . . . . . . . x x x x
. x x . x x x x . . x . . . x . . . x x . x x . . . x . x x x x
. . . . . . . . . . x . . . . . . . . . . . . . . . . . x x x x
Note that none of these groups covers the 1001
spot without covering the 1101
spot, which we need for Y
. You may be able to get the correct groups using a NAND
, NOR
, or XNOR
; but only if those count as 1 gate delay.
Note that if you are using a technology like CMOS logic where each bit has an inverse available, then using the Karnaugh map technique renders this problem trivial, with an example solution below (where a
is NOT A
, etc.):
X = AC + ABD + BCD
Y = Acd + abC + Abc + aCd + aBcD + ABCD
Z = bD + Bd
