I have an OEM touchpad I want to connect to a PC. The drivers for this touchpad are widely available. I asked the manufacturer for the original datasheet, and it says there, that the touchpad interface/protocol is PS2/SMBus.
On the device there is an 8 pin connector - of which 7 pins are used. They are laid out as follows:
I do know however that a PS/2 connector has only 6 pins (7 incl. the shield, but is it used at all?), and not 8. I can't see how this connector is compatible with PS/2.
FWIW, this is what the spec had to say about interface:
Interface
PS2
Refer to IBM PS2 specification. Internal pull-up resistors (5k typical) are provided on DATA and CLOCK lines.
All the commands specified by IBM are implemented, except for the following:
- "Scaling" and "Set Resolution" commands generate an "ACK" response from the touchpad, but leave the touchpad resolution unchanged.
SMBus
Refer to the System Management Bus (SMBus) Specification. Version 2.0.
That's it.
So am I looking here at something that is technically possible?
