I have an arduino kit (5v) and instead of just following their simple instructions I want to know why they are using certain resistors for their RGB LED's.
The RGB LED that comes with this is identical to this one. And I'm assuming the forward voltage and current is the same.
The directions call for three 220-ohm resistors, but is that necessary? My math tells me that Red needs a 100-ohm and the Green & Blue need 160-ohm's. Won't using more resistance decrease the luminosity of the LED?
Or maybe the resistors have something to do with the affect they are trying to achieve with the LED? Here's what the book states, which I don't really understand:
"By creating a voltage difference between the cathode and voltage coming out of the Arduino's PWM pins (which are connected to the anodes through 220-ohm resistors), you'll cause the LED to fade between its three colors."
Do the resistors have anything to do with this fading, or isn't it just the PWM controlling that?
