I am designing a board where I want to have the ability to separate the connection between two power net's by cutting a trace. Originally headers were meant to be used but due to size constrains I decided to go with this instead.
Googling terms like "PCB break trace footprint" and whatnot doesn't give much since it's mostly about how to fix those traces. So, what is the name of a footprint like this and where can I find more info on it? For example, recommended trace width, pad size, etc.
So far I have something like this where I can cut the two 6 mil traces, make a solder bridge if I need, and via's for if I need to solder wires with more rigidity than just relying on them being attached to the pads using solder.
