In particular, I would like to know what would happen if I crank the shaft of the following kinds of motor: brushed DC, brushless DC (the kind used in computer fans now) and 6-coil 3-phase AC permanent magnet synchronized motor (the kind that coils are used as stator and a permanent magnet rotating in the middle).
Would the cranked motor 1) energize a otherwise powerless line, or black start the line, 2) pushing out energy into a energized line, at least when the motor start get cranked, but does not work otherwise or 3) does not push out energy, and probably catch fire if cranked hard and long enough?
Assume that I have hooked the wires to a few resistors, and maybe an appropriate power source.
    \$\begingroup\$ Are the wires connected to anything? Because that matters. \$\endgroup\$ Commented Feb 5, 2015 at 15:48
  • \$\begingroup\$ @IgnacioVazquez-Abrams For an otherwise not energized line, resistors; for the feeding energy back to energized lines situation, resistors and an appropriate power supply. \$\endgroup\$ Commented Feb 5, 2015 at 15:51
  • \$\begingroup\$ I think this question is too vague still. We cannot "assume you have hooked up the wires to a few resistors and maybe an appropriate power source" because that is a very vague instruction. I think you should explain much more about why you are asking this and what scenario you are envisioning, otherwise we will just be guessing at what you are trying to figure out. \$\endgroup\$
    – user57037
    Commented Feb 5, 2015 at 20:20
  • \$\begingroup\$ @mkeith And what I am asking is how would the motor react with every possible resistor/power source arrangement. \$\endgroup\$ Commented Feb 6, 2015 at 5:45
The thing that you will do is to induce an EMF in the motors, which is plainly said a voltage.
For inducing an EMF you will need one thing: changing magnetic flux. So if it has absolutely no magnetization(which changes because of rotation) it won't work. This initial magnetization(for PM-less machines) can be brought in by inputting some DC, or unsymmetric AC. This way you get a magnetic axis, which isn't in the same place as your torque producing axis. With a cross product of the magnetic and torque producing axis you will get some force and torque, therefore they may not be the same.
Brushed motors
The brushed motors can have different excitations. We assume that the load is a resistor. Now let's take a look at the subtypes:
  • PM excitation: It will produce a DC voltage that is proportional to the speed. The torque-rpm graph is linear.
  • Parallel/Serial excitation: There needs to be some remaining magnetization in it, otherwise it is just some iron and copper. Assuming that it has this little magnetization you will get increase in current gradually, as it magnetizes itself. After some time it will stabilize. The speed will factor into the excitation and into the armature voltage. It can be calculated though, as the equations aren't complex. Parallel and serial will come to the same thing in this constellation.
  • Compound excitation: Will come to the same as parallel/serial, it will have a more complex model though.
AC-Machines
For three phase machines it will be assumed that 3 resistors are connected either in delta or wye, unless stated otherwise.
  • PM excited synchronous machine - It will work without problems, it will give 3-phase AC. The voltage and the frequency will be dependent on the rotational speed.
  • Reluctance synchronous machine - This one works with a magnetically asymmetric rotor/stator instead of having permanent magnets. It requires some remaining magnetization as said earlier. You should connect some capacitors on the load side as to give some phase shift to it, that way you will create phase shifted magnetization current. Based on this principle it could work fine.
  • AC Induction motor - This case will be similar to the reluctance synchronous machine. Capacitors and some remaining magnetization required.
  • BLDC Motor - basically the same as a PM excited synchronous. The difference lies in the output EMF, it will be trapezoidal instead of sinus like.
  • Single phase - Ask in the comments if you want them.
  • Electrically excited - Those are actually used in power stations, you need some current though for the magnetization. This DC excitation current can be created easily, but you need some additional equipment.
None of them will go into smoke except if you short them and crank to hard, but for this you need a large rotational speed. The power you put in through the crank will be used on the load(and in some cases for remagnetizing). Therefore even with a 100W bulb as load, you will be hard pressed to make it light up(as a normal human).
  • \$\begingroup\$ To round it up, brushed DC motors as found in toy cars can be cranked at its shaft and power a load on its own, pushing out DC power; as is the 3-phase 6-coil PMSM I wounded, albeit pushing out 3-phase AC power. The BLDC emits a more, well, interesting waveform if cranked, right? My test load would be an assortment of power resistors, LEDs and probably a small SMPS driving a small MCU, nothing too power-hungry. \$\endgroup\$ Commented Feb 17, 2015 at 16:53
  • \$\begingroup\$ @MaxthonChan You got it pretty much. Just be careful and use common sense. \$\endgroup\$
    – WalyKu
    Commented Feb 17, 2015 at 17:01
    \$\begingroup\$ Thanks. And that "crank a motor to light up a 100W bulb" can be a nice exercise :P (I am pretty obese actually) \$\endgroup\$ Commented Feb 17, 2015 at 17:04
