How do I make sure that my rise and fall times are balanced between input and output in a CMOS design?
  • \$\begingroup\$ Simulation of your design in whatever process node you're using. \$\endgroup\$
    – horta
    Commented Apr 1, 2015 at 5:03
Scale your pull-up PMOS circuitry to have the same conductance as the pull-down NMOS circuitry. For an inverter, this means scaling the PMOS to be 2-3× wider than the NMOS, because holes are 2-3× less mobile than electrons.
