I'm extremely new to circuits and am having some trouble with a variation on the voltage divider problems I've been doing.
I'm trying to determine \$V_{out}\$ in the following circuit relative to some \$V_{GND}\$ that I need to determine the location of
I know that in a standard voltage divider, the line to \$V_{out}\$ carries negligible current. In this case, I can't quite determine the current flow because the lines from \$V_2\$ and \$V_1\$ carry current that is equal to \$V_2/R_2\$ and \$V_1/R_1\$ at the point in between the two resistors. How does this return to ground, and how would I begin to apply Kirchoff's Law for the loop?
I would think that ground node positions would be like this, but I'm nevertheless confused about the current flow. Any advice would be appreciated.
