I was using MSP430G2553 with IAR Embedded workbench compiler which was working fine , then i recently installed Code composer studio and now the problem is when I run the same code
#include <msp430.h>
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
P1DIR |= BIT0; // Set P1.0 to output and P1.3 to input direction
P1OUT &= ~BIT0; // set P1.0 to Off
P1IE |= BIT3; // P1.3 interrupt enabled
P1IFG &= ~BIT3; // P1.3 interrupt flag cleared
__bis_SR_register(GIE); // Enable all interrupts
while(1) //Loop forever, we'll do our job in the interrupt routine...
#pragma vector=PORT1_VECTOR
__interrupt void Port_1(void) //ISR
P1OUT ^= BIT0; // Toggle P1.0
with CCS it is giving me an error
MSP430: Trouble Writing Memory Block at 0xc000 on Page 0 of Length 0xba: This operation is not supported by this driver
I checked the target configuration and all seems to be set to correct setting but still i dont understand how am I accessing a wrong memory location
EDIT : Project's makefile
SHELL = cmd.exe
CG_TOOL_ROOT := C:/ti/ccsv5/tools/compiler/msp430_4.2.1
ORDERED_OBJS += \
$(GEN_CMDS__FLAG) \
"./main.obj" \
"../lnk_msp430g2553.cmd" \
-l"libc.a" \
-include ../makefile.init
RM := DEL /F
RMDIR := RMDIR /S/Q
# All of the sources participating in the build are defined here
-include sources.mk
-include subdir_vars.mk
-include subdir_rules.mk
-include objects.mk
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(S_DEPS)),)
-include $(S_DEPS)
endif
ifneq ($(strip $(S_UPPER_DEPS)),)
-include $(S_UPPER_DEPS)
endif
ifneq ($(strip $(S62_DEPS)),)
-include $(S62_DEPS)
endif
ifneq ($(strip $(C64_DEPS)),)
-include $(C64_DEPS)
endif
ifneq ($(strip $(ASM_DEPS)),)
-include $(ASM_DEPS)
endif
ifneq ($(strip $(CC_DEPS)),)
-include $(CC_DEPS)
endif
ifneq ($(strip $(S55_DEPS)),)
-include $(S55_DEPS)
endif
ifneq ($(strip $(C67_DEPS)),)
-include $(C67_DEPS)
endif
ifneq ($(strip $(C??_DEPS)),)
-include $(C??_DEPS)
endif
ifneq ($(strip $(CLA_DEPS)),)
-include $(CLA_DEPS)
endif
ifneq ($(strip $(CPP_DEPS)),)
-include $(CPP_DEPS)
endif
ifneq ($(strip $(S??_DEPS)),)
-include $(S??_DEPS)
endif
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
ifneq ($(strip $(C62_DEPS)),)
-include $(C62_DEPS)
endif
ifneq ($(strip $(CXX_DEPS)),)
-include $(CXX_DEPS)
endif
ifneq ($(strip $(C++_DEPS)),)
-include $(C++_DEPS)
endif
ifneq ($(strip $(ASM_UPPER_DEPS)),)
-include $(ASM_UPPER_DEPS)
endif
ifneq ($(strip $(K_DEPS)),)
-include $(K_DEPS)
endif
ifneq ($(strip $(C43_DEPS)),)
-include $(C43_DEPS)
endif
ifneq ($(strip $(S67_DEPS)),)
-include $(S67_DEPS)
endif
ifneq ($(strip $(SA_DEPS)),)
-include $(SA_DEPS)
endif
ifneq ($(strip $(S43_DEPS)),)
-include $(S43_DEPS)
endif
ifneq ($(strip $(OPT_DEPS)),)
-include $(OPT_DEPS)
endif
ifneq ($(strip $(S64_DEPS)),)
-include $(S64_DEPS)
endif
ifneq ($(strip $(C_UPPER_DEPS)),)
-include $(C_UPPER_DEPS)
endif
ifneq ($(strip $(C55_DEPS)),)
-include $(C55_DEPS)
endif
endif
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables
# All Target
all: BlinkLED.out
# Tool invocations
BlinkLED.out: $(OBJS) $(CMD_SRCS) $(GEN_CMDS)
@echo 'Building target: $@'
@echo 'Invoking: MSP430 Linker'
"C:/ti/ccsv5/tools/compiler/msp430_4.2.1/bin/cl430" -vmsp --abi=eabi --advice:power="all" -g --define=__MSP430G2553__ --diag_warning=225 --display_error_number --diag_wrap=off --printf_support=minimal -z -m"BlinkLED.map" --heap_size=80 --stack_size=80 -i"C:/ti/ccsv5/ccs_base/msp430/include" -i"C:/ti/ccsv5/tools/compiler/msp430_4.2.1/lib" -i"C:/ti/ccsv5/tools/compiler/msp430_4.2.1/include" --reread_libs --warn_sections --display_error_number --diag_wrap=off --xml_link_info="BlinkLED_linkInfo.xml" --rom_model -o "BlinkLED.out" $(ORDERED_OBJS)
@echo 'Finished building target: $@'
@echo ' '
# Other Targets
clean:
-$(RM) $(MSP430_EXECUTABLE_OUTPUTS__QUOTED) "BlinkLED.out"
-$(RM) "main.pp"
-$(RM) "main.obj"
-@echo 'Finished clean'
-@echo ' '
.PHONY: all clean dependents
.SECONDARY:
-include ../makefile.targets
Makefile
. When you runmake
tool without arguments, it looks exactly for that file (starting from upper-casedM
). Thats why you can often find that IDEs use this file. \$\endgroup\$
