I'm trying to make my own full adder and some other devices as a sub-circuit in "Proteus" and use them several times in a bigger circuit.
The problem is when you copy a sub-circuit you need to rename all of its inner parts, otherwise, the parts with a same name in two sub-circuits would be considered as one, therefore you'd get some errors.
So I'd like to know if there is a way to define a full adder of my own and use it like "74LS183" which is a primitive device, and by primitive I mean it has been defined in the library.
