I have small doubt about power supply selection for a running motor. I have a small dc motor, which is rated for 12V , 3A(rated ). When the motor runs with a load 4000N, the current consumption is 1.5A.
So I have to choose a 12V, 3A = 12 * 3= 36W power supply to run the motor.This is because DC power supply can supply continous 3A current without any disturbance.
Now I wanted to run same motor on battery. I would like to know how much power should be supplied by the battery to run the motor theoretically.
When motor runs on battery, it takes full current from the battery; as per formula (\$e= l \frac{di}{dt}\$). It said that current required by motor = 3 \$\times\$ current required while running on starting.
When we run the motor on battery eventually battery voltage got dropped, taking more current.
I would like to know what is the percentage of current it takes.
If we consider above system 12V, 75Ah battery is it efficient?
Can someone explain with proper calculation here?
While running on battery; motor will turn on every 5 minutes and after that it will be turned off. The motor is made to run 11 hours on daily basis.
