I'm trying to galvanically isolate a device which is controlled by ethernet (1000base t) via computer. I've been looking and apparently the ethernet standard provides some isolation, but after I connect the cable to my otherwise isolated device to my computer, my multimeter reads short between its ground and earth ground. So clearly it's not isolating enough.
I'm wondering how I should proceed; according to wikipedia, gigabit ethernet is 8-bits, so a digital isolator won't work. Can anyone suggest a kind of chip that would work? They don't seem to make 8 bit digital isolators. In any case, it seems the ethernet signal can go below ground, so I'm not sure opto couplers would be a (direct) option, although I suppose I could bias them before and remove the bias after with a cap? It also seems like they are not fast enough for gigabit ethernet...
