The output of my Low Noise amplifier is a rough sinewave with a peak-to-peak of 1.7V and is shown in the oscilloscope trace below.
I would like to use one of the analog pins on the Uno to perform the analogue-digital conversion. However when I connect the analog pin to the output of my LNA the output immediately changes from a sinewave to sqaure wave and the peak-to-peak voltage rises (see trace below).
I even attempted to place a voltage buffer (follower) with no voltage gain in between the output of the LNA and analog Pin but this didn't solve anything. Again, as soon as I connected the analog pin the sinewave switched to a square wave.
int sensePin = 0;
int val = 0;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
//pinMode(analogPin, INPUT);
void loop() {
val = analogRead(sensePin);
Serial.println(val);
delay(200);
Any help/suggestions would be appreciated, I'm not sure what is wrong. Thanks
