I'm trying to obtain the input frequency of a square wave using the input capture register of an Atmega328p. So far, it works sporadically -- which is to say, when I input a 75 kHz square wave, the output looks like this:
244 244 75117 74766 75117 75117 79207 80402 82051 82901 84656 85561 87431 244 244 244 88888 90395 244 244 244 -941176 -271186 244 -246153 244 244 244
Does anyone know why this might be the case? I've tried messing with the data types, but otherwise I'm not really sure what the problem could be. The code I've written is below.
// # of overflows
volatile long T1Ovs;
// timestamp variables (store TCNT at time of input capture interrupt)
volatile long Capt1, Capt2;
// capture flag
volatile uint8_t Flag;
volatile long ticks;
volatile double period;
volatile long frequency;
void initTimer1(void)
TCNT1 = 0;
// initialize timer to 0
//timer/counter1 control register b
TCCR1B |= (1<<ICES1);
// input capture edge select; rising edge triggers capture
//timer/counter1 interrupt mask register
TIMSK1 |= (1<<ICIE1);
// ICIE1: input capture interrupt enable
TIMSK1 |= (1<<TOIE1);
// timer/counter1 overflow interrupt enable
void startTimer1(void)
TCCR1B = (1<<CS10);
//start timer with pre-scaler = 1
sei();
//enable global interrupts
ISR(TIMER1_CAPT_vect) // interrupt handler on input capture match (rising edge in this case)
if (Flag == 0)
Capt1 = ICR1;
// save timestamp at interrupt (input capture is updated with the counter (TCNT1)
// value each time an event occurs on the ICP1 pin (digital pin 8, PINB0)
T1Ovs = 0;
// reset overflows
if (Flag ==1)
Capt2 = ICR1;
Flag ++;
ISR(TIMER1_OVF_vect) // interrupt handled on timer1 overflow
T1Ovs++; // increment number of overflows
void setup()
Serial.begin(9600);
initTimer1();
startTimer1();
void loop()
if (Flag == 2)
ticks = Capt2 - Capt1 + T1Ovs * 0x10000L;
// (second timestamp) - (first stamp) + (# of overflows) * (ticks/overflow = 65535)
frequency = 16000000/ticks;
// ticks * seconds/ticks = seconds
// 1/seconds = Hz
Flag = 0;
// reset flags
T1Ovs = 0;
// reset overflow count
TIFR1 = 0b00000000; // clear interrupt registers
Serial.println(frequency);
TIMSK1 |= (1 << ICIE1); // enable capture interrupt
TIMSK1 |= (1 << TOIE1); // enable overflow interrupt
Thanks in advance!
UPDATE***********************************
The second iteration of code, using enumerated types to make a state machine:
typedef enum {
CAPTURE_1,
CAPTURE_2,
WAIT
} timer_state_t;
timer_state_t flag = WAIT;
void InitTimer1(void)
//Set Initial Timer value
TCNT1=0;
//First capture on rising edge
TCCR1B|=(1<<ICES1);
//Enable input capture and overflow interrupts
TIMSK1|=(1<<ICIE1)|(1<<TOIE1);
void StartTimer1(void)
//Start timer without prescaler
TCCR1B|=(1<<CS10);
//Enable global interrutps
sei();
ISR(TIMER1_CAPT_vect) {
switch(flag) {
case CAPTURE_1:
Capt1 = ICR1;
flag = CAPTURE_2;
break;
case CAPTURE_2:
Capt2 = ICR1;
flag = WAIT;
Serial.println(flag);
break;
T1Ovs++;
void setup()
Serial.begin(9600);
InitTimer1();
StartTimer1();
void loop() {
flag = CAPTURE_1;
while (flag != WAIT);
Serial.println("loop");
Serial.println(Capt2 - Capt1 + T1Ovs * 0x10000);
