I just obtained some of these counters for a project:
They have five connections for each slice labelled C, 1, 2, 4, and 8. As you increment the digit, the pins for the appropriate binary encoding are tied to the common pin.
I was hoping that I could tie all of the 1,2,4,8 pins together between all 5 digits, and then alternate which common pin was powered as I read the four common pins. That would let me read the whole unit with 9 pins.
Unfortunately the binary encoding causes connections on digits I am not reading to interfere with the digit I am interested in. I can't think of a good way to isolate the signals without just making 5x5=25 connections to my microcontroller, which I simply don't have io for. Is there a way to read this thing with fewer pins?
    \$\begingroup\$ Just FYI, these things are called "BCD thumbwheel switches"- they were quite popular back in the day. A "decade counter" is something quite different. \$\endgroup\$ Jul 3, 2015 at 4:12
  • \$\begingroup\$ That makes sense I only called it that because adafruit sells it as that. They also show a different connection pattern too, so maybe not the most accurate source. \$\endgroup\$
    – captncraig
    Jul 3, 2015 at 4:26
Diodes!
There's actually Hex and Dec counters like yours with that already built in (except the 4 resistors).
You pull one common low in this set-up (most common internal-diode scheme, so I drew that), usually with a MOSFET or Bipolar small signal device. If the corresponding switch is closed, the bit will read 0, if not, it WILL read 1.
You can of course easily flip this to be positive logic.
Small signal diodes come in 0603 and 0402 even, so if you'd want to do this on a volume board design, you could nearly invisibly integrate it into the row of pads where the counter connects.
  • \$\begingroup\$ So I just need 20 diodes and 9 io for 5 digits. I'm liking that, although I don't have the diodes handy. \$\endgroup\$
    – captncraig
    Jul 2, 2015 at 23:25
  • \$\begingroup\$ @captncraig can also use a bulk of OR ports or one hex input one, but that's ... eh... \$\endgroup\$
    – Asmyldof
    Jul 2, 2015 at 23:31
You would need a max of 4x5 = 20 inputs not 25 as the common pin is not sampled, but less is certainly possible (nine in the answer above).
You could connect 4 different value resistors to each pin and use them to generate a variable potential divider and read each switch with a single analogue input. You would need at least 6 bits of resolution to get unambiguous results, 8 bits would be easier as the resistor selection would not be as restrictive because your input would be maximised at half of the supply (though you could tune it to close to a lower vRef if available when at the max decimal value).
If you have the analogue inputs you could get away with 5 inputs, less if you add a multiplexor. You could use a 8 input MUX and a single count pin to drive a 3 bit counter to select the input. Connect up to 6 inputs to the mux and have the first input set to 0V and the last to Vcc and then the other 6 inputs would be at values between these (you could add one more resistor to bias the switch inputs above zero so your start and end channels are unique. This lets you get away with one output (shared with a status LED or something possibly) and one analogue input (the mux could input one other slowly varying signal on the spare pin like a current limit pot value or something) and some software.
As these are probably decade input switches you could use just one input to the mux as a framing voltage that you equate to the HEX 'F' value that cannot be generated by the switches. This will allow you to read 7 decade switches (instead of 6 HEX switches) with an 8 input mux. If you read all the switches twice and resolve the same setting you can be fairly secure in knowing that they have not been in the process of changing. The R2R or the 1R, 2R, 4R, 8R methods will both work, one has more components but can be just one or two resistor values, the other has fewer but possibly odd values.
If you have a 10 bit resolution analogue input you could possibly resolve 8 bits of resolution and do 2 switches with each signal or a total of 14 decade switches with 2 pins, perhaps not as reliable though.
Links to two answers here that will explain how to do it and the last link will show you lots of possible implementations if the above is not suitable or clear enough.
BCD Switch Resistor Network for Proportional Voltage Output
How should I use rotary switches and resistor networks to uniquely relate each possible combination of switch settings to an analog voltage?
https://www.google.com/search?q=bcd+to+analogue+resistors&tbm=isch&tbo=u&source=univ&sa=X&ei=kseWVYCvGMi1sQHzj4PwCQ&ved=0CCwQsAQ&biw=1400&bih=778#imgrc=JjeuJK-k9gTQsM%3A
