Context: I'm wanting to tinker around with some mini solar panels to power some old PC case fans I have laying around. I know that case fans are generally 12v so I was thinking of running some 3v panels in series. I know some basics from college but I'm pretty much a noob. I decided some experimentation was order.
My fan connector has 3 pins, so I identified the center one as the 12V and one on the side as the ground (the other goes to the tach, which I don't care about in this case - the power supply connector doesn't connect to this pin anyway).
First I measured the resistance. I get a reading of 14.48 on the 20kOhm scale which should be 14,480 Ohms. That seems very high to me because that would mean the fan runs on 0.83mA which seems very low.
I had an old computer power supply laying around so I shorted the power on pin and hooked up the fan (so nothing else is hooked to the power supply besides the fan). I confirmed that the voltage is right around 12V and when I hooked up the multimeter in series I get a current reading of 0.18A which is much more inline with what I would expect, but that means I should've gotten a resistance reading of around 66 Ohms.
I know I'm missing something obvious here, but I'm not sure what it is. Any help? Thanks!
