I am very new to electrical power math. So please be friendly. :-)
I am getting 28 gauge nichrome wire to make my own heating element. Here are the specs and numbers of what I am attempting to do and what I know. I would appreciate a second pair of eyes confirming my numbers and also help recommending the correct power supply.
A. 10ft of 28 gauge wire, straight = Ohms Resistance 42.52. I plan to coil the wire myself and then loop the coil through ceramic insulators B. I need to reach temperatures of 450 F (I don't need over, but I def need to consistently hit this temperature.
Using the above info, an online calculator has provided me the following:
Volts = 55.276
Required Amps. 1.3
Required Watts: 71.85
Resistance per foot: 4.252
Total Resistance: 42.52.
Questions:
Is 55.276 volts the amount of volts needed going into my power supply, or the amount of volts coming out of my power supply?
I have a spare (universal) HP laptop power supply with the following specs, is this power supply sufficient for my needs? : Input: 100-240v, 50-60Hz, 2.0A Output: 18.5v --- 6.5A, 120W
- When I cut the laptop connector off I assume I am going to see at least 2, probably three wires. black, white and green (maybe red). Do I connection both black/white to one end of the nichrome wire or do I connect black to one end and white to the other end?
A quick diagram:
110 Power Supply (PS) PS split Nichrome Wire
_________________________
3]---|>>100/240v | 18v/120W>>|____/---black---o---{Wire EndA}--\
------------------------- \---white---o---{Wire EndB}--/
- I may have to get 26 or 30 gauge wire...knowing the above, will my power supply still be sufficient with those gauge wires for what I am looking to do?
- Lastly, what, if anything am I missing or possibly not understanding?
Thank you in advance. This is all to make my own homemade plastic vacuum molding device.
