I've noticed that sometimes electronic engineers switch terms or have more than one term for the same thing. I wanted to ask, specifically in this question, what are these terms referring to:
  • Resistance looking into the base
  • Resistance from the base
  • Resistance looking into (the) "X"
  • Resistance from (the) "X"
  • Input impedance (or Thévenin equivalent?)
  • Output impedance (also Thévenin equivalent?)
  • If you think there is another term that might be worth clarifying that you know, I'd appreciate it!
Thanks a lot.
  • \$\begingroup\$ You should take (online or otherwise) an intro to circuit engineering or linear circuits class. Your questions about Thevenin will be answered, and about 80% of your first 4 questions will be answered. You'll spend a significant part of the class learning this stuff. It's not trivial. \$\endgroup\$
    – Daniel
    Commented Aug 9, 2015 at 5:54
  • \$\begingroup\$ A resistance is defined BETWEEN two points. Often the 2nd point is a common ref called "ground. In this case, it is common to specify an "input resistance". However, what means "...from the base" and "...from the X"? I never have heard such a term. \$\endgroup\$
    – LvW
    Commented Aug 9, 2015 at 8:17
Apply a test voltage (say 1V) and measure the test current. The resistance looking into the X is the test voltage divided by the current that flowed.
I'm not familiar with this usage.
Same thing as Resistance looking into (the) "X"
Same thing as the resistance in a thevenin equivalent.
    \$\begingroup\$ resistance from 'x' could mean an external resistor perhaps? - it's hard to guess without context. \$\endgroup\$ Commented Aug 9, 2015 at 7:54
