I'm brushing up on my high school electronics knowledge and I decided to experiment with a small acquarium pump I had lying around. I took some measurements with a multimeter and the results confuse me to no end. The readings don't appear to correspond with Ohm's law, the current draw appears to differ, etc, and now I'm stumped.
I have this small pump hooked up to two AA batteries. According to the (sparse) data sheet, it's rated for 3V and draws a current of "< 460mA". Using the multimeter to read the battery voltage (with nothing connected) I got 3.18V, which makes sense because they were fresh AA batteries. I then decided to connect the pump and read the voltage on the two connectors on the pump. This read 2.9V, which was surprising to me because apparently 0.28V had disappeared. The wires from the battery to the pump are both only a couple of centimeters long, so this seems like a lot of voltage to lose on such short wires. I then inserted the multimeter in the circuit and measured 0.19A. Finally, I measured the pump's resistance, which was 3.5 Ohms.
Now, according to Ohm's law, U = I * R, so 0.19A * 3.5 Ohm = 0.665V. A far cry from 3.18V or even the 2.9V I measured on the pump. How is this possible?
Trying something else, I hooked up the pump to a 5V molex connector from an old PC's power supply. Measuring voltage on the molex connector, I get 5.04V. Measuring on the pump's connectors, I get 4.92V. Inserting the multimeter in the circuit, I suddenly read 0.28A. So apparently, the pump suddenly draws 200mA more than it did before, which seems weird: isn't a component supposed to just draw the current it requires? Throwing these numbers in Ohm's law gets me 4.92 / 0.28 = 17.575. Also not the 3.5 Ohms I measured.
Finally, I decided to add some resistors to drop the 5V from the molex down to roughly 3V. I added a couple of 1 Ohm resistors in series which resulted in a measured resistance of 4.3 Ohms. Now, if I insert the multimeter into the circuit I get 0.24A, yet again a different current. Measuring voltage across the resistors I get 0.98V, and measuring across the pump I get 3.93V. 0.24A * 4.3 Ohms = 1.032V, which isn't the 0.98V I measured.
I'm apparently missing something fundamental about circuits or Ohm's law, but I can't figure it out. I considered the fact that the pump's resistance changes when it is connected, but then it still doesn't make sense that the values I measured on the resistors don't follow Ohm's law either. What am I missing?
